08-27-2009, 08:21 AM | #1 |
Rock Stacker Join Date: May 2009 Location: SoCal
| Advice
I'm always seeking the advice of the people on here rather anywhere else...I have NO IDEA what to do when it comes to airbrushing so if you where to help someone piece together everything needed to do some painting what would you recommend for the air tank, brush gun, etc. Just been considering the airbrush rather than cans.
08-27-2009, 09:09 AM | #2 |
Rock Stacker Join Date: Sep 2008 Location: Lake Havasu City
For a brush I use a Sotar 2020 or that Parma F1. My F1 is the older style that uses the bottle adaptor (the new is gravity feed). I like and use this brush more for easy clean up and fast color changes. Cost wise the F1 is around 125.00, the Sotar 400.00. I use a standard shop compressor, but a airbrush compressor from Harbor Freight will work....cost about 60.00. Just make sure you use a inline filter with adjustable pressure. I not a pro, just my advise.
08-27-2009, 09:06 PM | #3 |
I wanna be Dave Join Date: Dec 2007 Location: Florida
You definitely want a gravity feed airbrush. I recommend the Iwata Revolution HP-CR which will run you about $75. For a compressor the Craftsman 3 gallon works great with a moisture trap.
08-28-2009, 12:25 PM | #4 | |
RCC Addict Join Date: Mar 2009 Location: In a very dark cave can't you tell...
| Listen to Him Quote:
Crawler Graphics does great work, so you should follow his lead on this one. | |
