02-13-2010, 11:48 PM | #1 |
Newbie Join Date: Jan 2010 Location: north hollywood
| stripping paint of hilux body?
hi just wanted to repaint my hilux body and was wondering what i can do to strip the paint off of it. can i used paint thinner? would that melt the hard plastic body or should i just use sand paper? thanks in advance |
02-13-2010, 11:55 PM | #2 |
Rock Crawler Join Date: Sep 2008 Location: Salem,Oregon
dont use paint thinner
02-14-2010, 01:05 AM | #3 |
Quarry Creeper Join Date: Mar 2009 Location: Peoples Republic of Kalifornia
There is a citrus based called Citreaze(sp), that would probably work really well. I have used it on various polymers and it has done nothing to the plastics.
02-14-2010, 07:50 AM | #4 |
Rock Crawler Join Date: Sep 2005 Location: Duncan, BC, Canada
I've stripped a few hard bodies with Easy-Off (yellow top). works quite well, may require a couple applications depending on the piants used. It won't harm the plastic (I've done both styrene and ABS bodies with it) |
02-14-2010, 04:54 PM | #5 |
I'm a stupid C U N T! Join Date: Jun 2005 Location: In the Garage!
Chameleon Stripper its made just for styrene and plastic paint removal. It works very well http://www.chameleonproductsonline.com Last edited by slobin3d; 02-14-2010 at 04:56 PM. |
02-17-2010, 12:54 AM | #6 |
thanks will try them out :-)
02-17-2010, 02:11 PM | #7 |
Rock Stacker Join Date: Aug 2008 Location: USA
Automotive brake fluid(DOT3) stripped the paint off my Blackfoot extreme body without harming it. If you do try brake fluid, though, wear gloves(it will dry out your hands), use in a well ventilated area(very strong smell), and don't use on chrome or transparent parts(it will fog them).
07-19-2010, 05:52 PM | #8 |
I joined the Band! Join Date: May 2009 Location: lake county ,florida
brake fluid(DOT3) and easy oof with the yellow top are the best ways i have found use a trashbag to put the body in and put it in the sun also wear gloves and be patient.
