03-02-2010, 11:10 PM | #1 |
Rock Stacker Join Date: Oct 2009 Location: Longview, Wa
| Painting lexan body outside
Want to paint the outside of a lexan body a flat olive green. I know when you paint them even on the inside your supposed to use the specific paint that will flex with the body and not crack and chip. What kind do I use for the outside? Will the paint you use on the inside be flat if sprayed on the outside? Any help is appreciated
03-02-2010, 11:21 PM | #2 |
RCC Addict Join Date: Sep 2007 Location: Hallsville, Tx
you can use createx paint and they also have a matte/flat clear that will work. which longview you live in, texas or washington?
03-03-2010, 02:39 PM | #3 |
Washington, where it rains 10 months out of the year. |
03-03-2010, 03:09 PM | #4 |
The lexan paint is not quite "flat" when sprayed on the outside of the body but is is more of a satin or matte finish.....I guess. Here are two bodies I painted on the outside using Pactra lexan paint. |
03-03-2010, 08:58 PM | #5 |
I did this using a light coat of Bulldog followed by some camo green in a rattle can. |
03-05-2010, 03:53 PM | #6 |
Pebble Pounder Join Date: Feb 2010 Location: USA
So all lexan-compatible paint is created equal? Also, I've seen a lot of people put detailing and ink washes, and sealer coats over external lexan paint. Can any paint be used for that, applied over the lexan paint? |
03-05-2010, 04:20 PM | #7 |
Rock Crawler Join Date: Jan 2008 Location: Eveleth
I painted a body using Krylon Fusion paint. It is for plastic patio furniture. I did shoot the outside with Fascolor Silver, then topped that with the Krylon paint. It has held up really well. I laid down the silver first so once the black is scratched it looks like bare steel. I also painted the inside using Tamiya copper for lexan so once the silver is scratched it looks like rust. Here is a pic.... The woodgrain and gas can were also painted on the outside using Fascolor paints. |
03-05-2010, 08:10 PM | #8 | |
Btw what is that bitchin' body you're using? | |
03-05-2010, 10:20 PM | #9 | |
03-06-2010, 06:31 AM | #10 |
The body is an Axial B17. Comes with the AX10 kit.
