03-24-2010, 10:18 AM | #1 |
RCC Addict Join Date: Jan 2010 Location: Barboursville, WV
| painting lexan outside - questions Ok, the body I am getting ready to paint has the overspray film on the outside. Should I leave that on as my mask while painting, or do I need to remove it and scuff/wash the outside of the body before I paint? Or do I need to scuff the body at all? What's the best way to mask the outside of the body...overspray film, bob's paint mask, or blue painter's tape? I'm planning on using some rustoleum primer to paint the inside to give it that rust look and then pactra lexan paint cans to paint the outside of the body. |
03-24-2010, 10:26 AM | #2 |
Quarry Creeper Join Date: Dec 2008 Location: Santa Mira
Just remember if you paint the outside your paint job will get scratched up! I always paint on the inside and it still gets scratched a little!
03-24-2010, 10:28 AM | #3 |
| I know, that's the idea. If I paint it to look like rust inside and then spray the color outside when it gets scratches on it it will appear as though the scratches are rusting through. |
03-24-2010, 04:02 PM | #4 |
RCC Addict Join Date: Sep 2007 Location: Hallsville, Tx
pull the cover off, if you use it as a paint mask the paint will actually bleed under it. it wasnt designed to use that way, it was to help keep the overspray from getting on the outside.
03-24-2010, 06:32 PM | #5 |
03-25-2010, 10:02 AM | #6 |
| Thanks! I wasn't sure how well those are stuck onto the body. Anything else I need to be careful with or any tips for masking the outside of the body? |
03-25-2010, 10:07 AM | #7 |
Rock Crawler Join Date: Jun 2009 Location: Colorado Springs
If you are using masking tape just be sure to get all the edges down good. thats a area that will get the most bleed if you dont take care in masking. Dont go overly thick with the paint either, if you do it will flake off and not scratch off
03-25-2010, 10:15 AM | #8 |
Quarry Creeper Join Date: Nov 2008 Location: Cincinnati
| I have had a completely different experience. I have painted the outside of Proline and HPI bodies using the overspray film as a protective mask. I use a hobby knife to cut it then peel the rest of the overspray film off, leaving the cut stuff where I do not want paint. I have had great success with it. The lines have been very crisp and clean.
