Go Back   RCCrawler Forums > RCCrawler General Tech > Paint and Body
Thread: painting lexan outside - questions
Old 03-24-2010, 10:18 AM   #1
Question painting lexan outside - questions
Ok, the body I am getting ready to paint has the overspray film on the outside. Should I leave that on as my mask while painting, or do I need to remove it and scuff/wash the outside of the body before I paint? Or do I need to scuff the body at all?
What's the best way to mask the outside of the body...overspray film, bob's paint mask, or blue painter's tape?
I'm planning on using some rustoleum primer to paint the inside to give it that rust look and then pactra lexan paint cans to paint the outside of the body.
brianw is offline   Reply With Quote
Old 03-24-2010, 10:26 AM   #2
Just remember if you paint the outside your paint job will get scratched up! I always paint on the inside and it still gets scratched a little!
MexicanMarauder is offline   Reply With Quote
Old 03-24-2010, 10:28 AM   #3
Wink
I know, that's the idea. If I paint it to look like rust inside and then spray the color outside when it gets scratches on it it will appear as though the scratches are rusting through.
Old 03-24-2010, 04:02 PM   #4
pull the cover off, if you use it as a paint mask the paint will actually bleed under it. it wasnt designed to use that way, it was to help keep the overspray from getting on the outside.
jwalker is offline   Reply With Quote
Old 03-24-2010, 06:32 PM   #5
On the lookout for Rocks
constantmotion's Avatar
Ditto...you'd make a good mess of it using it as a mask.
constantmotion is offline   Reply With Quote
Old 03-25-2010, 10:02 AM   #6
Thanks! I wasn't sure how well those are stuck onto the body.
Anything else I need to be careful with or any tips for masking the outside of the body?
Old 03-25-2010, 10:07 AM   #7
If you are using masking tape just be sure to get all the edges down good. thats a area that will get the most bleed if you dont take care in masking. Dont go overly thick with the paint either, if you do it will flake off and not scratch off
neoakaj is offline   Reply With Quote
Old 03-25-2010, 10:15 AM   #8
I have had a completely different experience. I have painted the outside of Proline and HPI bodies using the overspray film as a protective mask. I use a hobby knife to cut it then peel the rest of the overspray film off, leaving the cut stuff where I do not want paint. I have had great success with it. The lines have been very crisp and clean.
ebbet is offline   Reply With Quote
