08-02-2010, 11:26 PM | #1 |
Pebble Pounder Join Date: Dec 2008 Location: Columbus, IN
| Paint match help
OK guys I am doing a Cherokee body on my SCX10 pretty soon and was wondering where to find paint to match my 1:1 rig. Here is the rig: The color is called gunmetal blue metallic. Any suggestions? |
08-03-2010, 10:34 PM | #2 |
Rock Crawler Join Date: Jun 2010 Location: Colorado Springs
Try Tamiya paints. They seem to have a wide variety of colors. Or if you can use an airbrush you could always mix your own. Good luck |
08-03-2010, 11:12 PM | #3 |
08-04-2010, 07:12 AM | #4 |
Quarry Creeper Join Date: Sep 2008 Location: Tualatin, Eugene Or
Most good auto body paint suppliers can mix paint and put it in a aerosol can. I use to have this done all the time when I worked at a diesel performance shop color matching parts to the body color or interior color. If you find one that can do that give them the paint code from your jeep. And they will mix a perfect match |
08-04-2010, 01:10 PM | #5 |
RCC Addict Join Date: Feb 2006 Location: Bellflower, CA
go to automotivetouchup.com and type in the year, make, and model and they can get your paint code. 12oz aerosol can is kinda pricey @ 19.99 but i guess its worth it if you can match it up perfectly. ill let you all know once i
08-04-2010, 03:16 PM | #6 |
Good ideas, but wouldn't automotive paint chip off the body? That's why there is paint specially made for the lexan bodies. |
08-04-2010, 05:00 PM | #7 |
RCC Addict Join Date: Oct 2008 Location: PA
08-07-2010, 01:13 AM | #8 | |
08-08-2010, 08:18 PM | #9 |
Rock Stacker Join Date: Mar 2009 Location: St louis
| paint codes
The paint code is located on the drivers door ,It tells you everything from trim ,to paint colors ,I Have a white 2000 cherokee and my paint code is PW1 ,It is just below the bar code on that sticker ,it also says paint then the code .plasti color is a good brand ,can be found at most auto paint shops ,pretty cheap .I payed 7.00 a can .hope this helps .
09-21-2010, 04:33 PM | #10 |
Newbie Join Date: Sep 2010 Location: Clay Co.
Got this thing done yet Flex? Lets see it!
