12-17-2010, 01:29 PM | #1 |
Newbie Join Date: Nov 2010 Location: earth
| Gaps Hinges etc.
I'm about to paint Tamiya lexan land cruiser body. It's going to be white. I want to darken the hood and door gaps, hinges, vents etc. My plan is to spray some Tamiya PS "smoke" into a cup for this. I would do this on the underside prior to painting the body color. Using a very fine detail brush with very little paint on it, I'll just highlight these lines outlining the door hood vents etc. Is this a workable idea?
12-17-2010, 07:59 PM | #2 |
RCC Addict Join Date: Sep 2007 Location: Hallsville, Tx
it sounds like it works but i am not a big fan of painting dark lines for gaps but this is your rig. if you look at a 1:1 rig next to a scale rig with gaps painted in it doesnt look scale but more cartoony. a full size rig wont have huge gaps and they wont be dark at all but more of the same color. but like i said this is your rig so make it your own. |
12-17-2010, 10:31 PM | #3 |
Rock Crawler Join Date: Aug 2010 Location: Salt Lake
you could always try it out on a junk body first. I think a thin and light enough coat that just makes the color a bit darker would look pretty good. might even think about applying it to the outside after it's done so you don't have to be as exact with the brush.
12-17-2010, 10:57 PM | #4 |
| That's what I was thinking, just a tad darker. Somehow, gaps and vents and even things that rise above the surface like bolts are apparent because the same light cannot be in every single place at once. Usually, it's a shadowing effect that outlines these places. So, a very light darkening. That's why I thought the smoke, for window tint effect, might help to keep it light, like a shadow.
