01-17-2011, 03:27 AM | #1 |
Quarry Creeper Join Date: Jan 2007 Location: Osaka, Japan
| CA fogging blocker?
Is there any way to prevent CA (superglue) from fogging clear parts? I scratchbuilt a lightbar last night that I was pretty happy with, but didn't consider the fogging effect, and now it's not so pretty. Not the actual contact area, which is hidden, but the area around that. I need to bond aluminum to plastic, I guess I could go buy some epoxy, but that's more time and expense than I'd prefer if there's a way around it. Any suggestions would be greatly appreciated. -val Last edited by LAV25; 01-17-2011 at 03:28 AM. Reason: unclear title |
01-17-2011, 05:26 AM | #2 |
I believe it is the fumes that causes this....set it in front of a fan to let it dry.
01-17-2011, 06:42 AM | #3 |
Newbie Join Date: Jan 2011 Location: Flushing
I use a lot of CA glue in my woodworking business. While it will fog on wood as well as plastic, I usually find when using the med. or heavy viscosity version, that by allowing the glue to set just a bit longer before hitting it with the accelerator and spraying it with a lighter mist from a bit further away will often prevent the fogging. I have not found it to compromise the bond.
01-17-2011, 06:44 AM | #4 |
Use ShooGoo
01-17-2011, 06:54 AM | #5 |
www.team3sixrc.com Join Date: Mar 2008 Location: Scalerville
CA or Super glue will always do that. The only way to avoid that is to tape off the area close to the glueing point with masking tape or better yet parma liquid mask. Then remove when done. Some of the other options would be epoxy, or a better r/c application of shoe goo or stronger still, E-6000 which can be picked up in the craft isle of walmart for $2.99 . A less flexible but strong glue is gorilla glue.
01-17-2011, 07:10 AM | #6 | |
Rock Crawler Join Date: Jul 2008 Location: E. City
01-17-2011, 07:54 AM | #7 |
Thanks guys, I'll have to dig around. Kind of a random thought, when I told a friend of mine (not an RC guy) about the problem, he suggested just masking the area with either cellophane tape or smearing (gack) butter on the area meant to remain clear.... Crazy? -val |
01-17-2011, 07:57 AM | #8 | |
-val | |
01-17-2011, 08:20 AM | #9 |
Cello tape will bond. CA melts thin plastic. and as far as E-6000 goes. It will fully cure in about an hour. remember, patience wins always. And yes, you'll have less fogging with gel. You shouldn't use alot at all. That's what I use to bond my scale parts Last edited by team3six; 01-17-2011 at 08:23 AM. |
01-17-2011, 09:22 AM | #10 |
Pebble Pounder Join Date: Mar 2005 Location: Nebraska
Using a kicker(accelerator), and good ventilation will solve the problem. Works for me.
01-17-2011, 10:24 AM | #11 |
Quarry Creeper Join Date: Sep 2008 Location: Tualatin, Eugene Or
Use canopy glue for R/C planes. It is made not to fog so the when gluing the canopy down you dont have that issue, Thats what I used on my RPM light bar to glue the lenses in and it is clear as day Pic so you can see it |
01-17-2011, 11:02 AM | #12 | |
DOOH!!! Join Date: Feb 2007 Location: AZ
Either RC56 from Tower http://www3.towerhobbies.com/cgi-bin...&I=LXR529&P=ML or this http://www3.towerhobbies.com/cgi-bin...?&I=LXHE49&P=7 Can't remember the other manufacturer, comes in a little white bottle with blue writing.. | |
01-17-2011, 02:47 PM | #13 | |
Thanks to all! -val | |
01-17-2011, 02:58 PM | #14 |
This will clean it up. Fashine PAR40203 |
01-17-2011, 03:10 PM | #15 |
simple, use CA kicker and fogging will never happen. they do make some ca remover you could rub on/off after the damage is already done. but the kicker will prevent it from ever happening. |
