Go Back   RCCrawler Forums > RCCrawler General Tech > Paint and Body
Thread: How to remove sticker skum!!!
Old 01-18-2011, 06:44 PM   #1
Default How to remove sticker skum!!!
Im trying to remove a sticker on my xr body but it left this sticker skum. Ive tried goo gone and lighter fluid which made it worse! It spread every where and is this haze of goo. Its driving me insane! Is there some way to get rid of this? Please Help!!!
lipbr302 is offline   Reply With Quote
Old 01-18-2011, 06:46 PM   #2
Bug/tar remover or paint thinner.
justinart24 is offline   Reply With Quote
Old 01-18-2011, 07:16 PM   #3
Jer
I use Acrysol at work, I have NEVER had it remove anything I didn't want it to. I have used it on everything from marker on car paint, to tar on plastic trim pieces. Leave no residue whatsoever, never discolores. You can get it in a spary can too.
Jer is offline   Reply With Quote
Old 01-18-2011, 07:19 PM   #4
I have good luck with motor spray!
jcboof is offline   Reply With Quote
Old 01-18-2011, 07:24 PM   #5
i put some gas on a cloth and it takes two wipes and its gone, i have had worse and it works every time
crawling-wallz is offline   Reply With Quote
Old 01-18-2011, 07:39 PM   #6
I use label, sticker remover that you buy at napa, autozone. Works great
PhantomRS10 is offline   Reply With Quote
Old 01-18-2011, 07:56 PM   #7
You can also use some zippo lighter fluid.
easleycrawler is offline   Reply With Quote
Old 01-18-2011, 08:29 PM   #8
Wd40
NorZepol is offline   Reply With Quote
Old 01-18-2011, 08:30 PM   #9
I have had luck using the sticky side of duct tape. Stick it to the sticky residue and pull it off quickly.
spcustoms is offline   Reply With Quote
Old 06-11-2011, 02:46 AM   #10
Hand Cleaner like Go-Jo
themerc64 is offline   Reply With Quote
Old 06-11-2011, 03:15 AM   #11
be careful with something like googone on lexan, it will fog it. Whatever you use try it on a small patch to see how it reacts.
forbid89 is offline   Reply With Quote
Old 06-11-2011, 06:10 AM   #12
use Oups, its wayyyyy better than goo gone. Ive used it to take sticker residue off my 1:1 truck and worked great!
2500hdon37s is offline   Reply With Quote
Old 06-12-2011, 03:38 PM   #13
RainX antifog
hotwheels000 is offline   Reply With Quote
Old 06-12-2011, 04:35 PM   #14
Originally Posted by NorZepol View Post
Wd40
I have used this to remove sticky mess for years. Works like a charm every time.
TexasSP is offline   Reply With Quote
Old 06-12-2011, 04:52 PM   #15
peanut butter... swear on my life. My mom showed me that years ago. spread some on. let it site, the oils in the peanut butter eat up the adhesive. then wash off.
TANK is offline   Reply With Quote
Old 06-12-2011, 07:04 PM   #16
x3.
shelby is offline   Reply With Quote
Old 06-12-2011, 08:21 PM   #17
alittle nitro fuel on a rag
stanmondz is offline   Reply With Quote
Old 06-12-2011, 09:31 PM   #18
a can of gasoline and a lighter will take care of the sticker goo on your body
CrawlHer is offline   Reply With Quote
Old 06-14-2011, 10:52 AM   #19
goo gone works for me
SNCrawler is offline   Reply With Quote
Old 06-15-2011, 08:35 AM   #20
I'm surprised to find that no one has said anything about the hair dryer trick. To remove decals and stickers from any of the bodies I have had......I just take a hair dryer and heat up the sticker/decals and you can just pull them right off, 9 times out of 10 theres no mess left.
Give it a try next time.
IceBox84 is offline   Reply With Quote
