03-03-2011, 05:07 PM | #1 |
Newbie Join Date: Dec 2010 Location: folsom
| lexan paint
how long between each coat should i wait and im doing very light coats
03-03-2011, 05:18 PM | #2 |
RCC Addict Join Date: Jun 2009 Location: Salmon Arm BC
until its dry... hahaha... if the body is inside a heated garage/shop or the house it shouldnt take more than like 1hour to dry.. sometimes 45mins. i could be wrong its been a while since i've painted a lexan body.
03-03-2011, 07:06 PM | #3 | |
Rock Stacker Join Date: Feb 2011 Location: Central
I alway used to clean the body well , do a lite coat and let it tack up (5 - 10 mins) then hit it with another lite coat , repeat this process a couple of times.If you are pulling a mask of for a 2nd color I like to let it get about 95% cured then pull the mask off nice and slow. | |
03-04-2011, 01:33 AM | #4 |
Quarry Creeper Join Date: Jan 2011 Location: armstrong
ya also if you want to help the paint cure you can use a heat gun on the lowest setting or a blow dryer just move around a lot that way you don't warp the body or boil the paint just remember to do really light coats I allowed 15-20 min between coat you can also look on the can there will be a guide on it also
03-04-2011, 03:24 AM | #5 |
Quarry Creeper Join Date: Jun 2009 Location: Minnesota
a blow drier on low and until you see the shine of the paint go away. Usually take about 2-3 minutes. Repeat until you hold the body up to the light and cant see through it anymore.
03-05-2011, 07:39 AM | #6 |
Quarry Creeper Join Date: May 2009 Location: Under Communist Occupation
also depends on what effect you may be going for.
03-05-2011, 09:01 AM | #7 |
Newbie Join Date: Dec 2010 Location: LKN
I usually will rub a masked area like the windshield with my finger and if it doesn't smudge, its ready for another coat. Carefull with a heatgun or blow drier, you can warp the body if it gets too hot.
