Go Back   RCCrawler Forums > RCCrawler General Tech > Paint and Body
Thread: Liquid mask?
Old 01-01-2012, 02:01 PM   #1
Default Liquid mask?
Ok i am a somewhat newb to using Liquid Mask and was wondering. After I apply the Liquid Mask and it dries all nite long can i rewash the body or do I just take a good damp cloth to it.
Onebdgti is offline   Reply With Quote
Old 01-01-2012, 04:35 PM   #2
Default Re: Liquid mask?
Should have washed the body before you applied the liquid mask.
maxfactor is offline   Reply With Quote
Old 01-01-2012, 04:49 PM   #3
I did last night. Just wanted to make sure that it was all clean before throwing the paint on it today. DUH
Old 01-02-2012, 11:26 AM   #4
If you properly cleaned it before masking it then you don't need to clean it again. just keep your fingers off the spots that you have peeled so you don't get any oil on the body. or do what I do and wear gloves when peeling and painting.
Liquimask doesn't leave a residue on the body, just peel and paint.
Also since this seams to be your first time using it make sure you put it on REALLY thick. Or gonna have a total PITA time cutting it with out cutting your body and it will be a bitch to peel.
street.terror is offline   Reply With Quote
Old 01-02-2012, 11:44 AM   #5
if you use any color flop paint after you peel the liquid mask off you can see your brush marks in the paint. if just using solid colors you cant see any marks. i always use about 3 good coats and use a hair dryer to help dry the liquid mask faster.
jwalker is offline   Reply With Quote
Old 01-02-2012, 12:00 PM   #6
I got it all figured out. I was painting the outside of the body and the next day i went to paint it and a friend came by and picked up the body that why I asked the question.
Liquid mask? - Similar Threads
Liquid mask: First try. RIG_RIDER Paint and Body 15 05-12-2011 10:13 AM
liquid mask alternative dusty sweep Paint and Body 12 12-23-2010 08:25 AM
liquid mask foolish 1 Paint and Body 10 09-06-2010 04:36 AM
liquid mask on styrene? dieselfuel Paint and Body 6 02-19-2009 02:08 PM
liquid mask Nub-4-life General Crawlers 20 01-15-2007 06:43 PM
