Go Back   RCCrawler Forums > RCCrawler General Tech > Paint and Body
View Poll Results: Should I go aluminum on my wraith body panels?
Hell yes! 7 100.00%
Flip No! 0 0%
Voters: 7. You may not vote on this poll
Thread: Painting Aluminum body panels!!
Old 12-04-2011, 02:59 AM   #1
Post Painting Aluminum body panels!!
Couldnt find a way to paint aluminum body panels for my wraith.
And one got a good detailed way todo that?
Or a link pictures would be nice to..
Mr.Tek is offline   Reply With Quote
Old 12-04-2011, 08:59 AM   #2
THW
Clean the panels with a drop of soap in a gallon of water.
Rinse really well with warm water and dry.
Wipe down with wax remover/degreaser.
Prime with self etching primer.
Paint.
THW is offline   Reply With Quote
Old 12-05-2011, 12:39 PM   #3
Location: Taylors Falls just hanging with the MNRCRC crew.
I always have had good luck by giving the piece a couple of light coats drying in between coats of "Bull Dog" adhesion promoter, it makes paint tougher than anodizing. You can pick it up at Walmart or Auio Body stores a little bit goes a long way.
Stormin2u is offline   Reply With Quote
Old 12-05-2011, 09:11 PM   #4
is the aluminum shiny?? if it is you'll have to sand it down a bit first because the paint wont stick to shiny alum. then if you want can add adhesion promotor then prime and paint. after the primer if you want a smooth paintjob sand down the primer a bit then paint..
AX10wannabe is offline   Reply With Quote
