Go Back   RCCrawler Forums > RCCrawler General Tech > Paint and Body
Thread: Painted body before drilling post holes oops
Old 12-08-2011, 02:40 PM   #1
Default Painted body before drilling post holes oops
How can I line up and mark the body? I was thinking of putting clay inside the body near where each hold should be then positioning the body where i want it. Then by pushing down on the body it would make an indentation in the clay where I need to drill. OR is there an easier way?
strap624 is offline   Reply With Quote
Old 12-08-2011, 03:16 PM   #2
Take a little bit of dash soap. liquid kind and dab on the body posts. get the body where u want then drop it on the posts. the soap will leave a marking where to reem the body
PhantomRS10 is offline   Reply With Quote
Old 12-08-2011, 04:00 PM   #3
Its a HARDKNOCKZ Life...
HARDKNOCKZ's Avatar
BINGO!!
I use paint but anything will work really.
J.D.
HARDKNOCKZ is offline   Reply With Quote
Old 12-08-2011, 04:05 PM   #4
MODERATOR™
EeePee's Avatar
I used grease. And maybe shock oil too. Yep, anything that leaves a mark is good.
EeePee is offline   Reply With Quote
Old 12-08-2011, 04:28 PM   #5
You can also use a flash light. Look at your vehicle from above the body while shining a flashlight from below it (aimed at the body post(s). You should be able to see the body post this way as long as the paint is not to thick. Then just mark it and drill.
I like the idea of putty though. May be even easier then the flashlight.
Rook82 is offline   Reply With Quote
Old 12-08-2011, 04:35 PM   #6
...ketchup. lol. thats what I have used.
dont know about you guys but I know I have too many unused packs from drive throughs
baconCHDDRchips is offline   Reply With Quote
Old 12-09-2011, 09:38 AM   #7
Marker-sharpe
whalebone is offline   Reply With Quote
Old 12-11-2011, 12:21 PM   #8
How about lining it up while the body is still clear and take a sharpie marker and mark the center of each body post. Then when it's all painted, you have these spiff-O-matic dots, right where you need to drill and ream!
DiggyStyle is offline   Reply With Quote
Old 12-11-2011, 02:27 PM   #9
He already painted it
He can't turn back now.
salmonfacesalad is offline   Reply With Quote
Old 12-11-2011, 02:45 PM   #10
Well, I guess it's time to strip the paint off and start over, marking the body posts first.
Devil Inc is offline   Reply With Quote
