03-17-2012, 07:09 PM | #1 |
Rock Stacker Join Date: Mar 2008 Location: honolulu
| pactra backing black?
Just bought pactra Inca gold and it say to use backing black to get effect of the color.can't I use just black pactra paint to back it?will it make the paint run?
03-17-2012, 07:36 PM | #2 |
SORRCA Committee Member Join Date: Dec 2008 Location: Parkston, SD
| Re: pactra backing black?
I've always used the backer with those paints. Not sure what it would do. The other positive with using the backer black is I have used it on the outside of the body since it dries flat. |
03-18-2012, 12:01 AM | #3 |
Thanks R2J That Bronco is sick!
03-18-2012, 06:02 AM | #4 |
Rock Crawler Join Date: Aug 2008 Location: B.C.Canada
Backing black is NOT designed to go directly on polycarb plastics. It's designed to stick to other paints {as a backer} or regular plastic. If you put it directly polycarb and/or use it as a regular black paint it cracks easy and flakes off when the body flexes. |
03-19-2012, 03:59 AM | #5 | |
Nope.. Join Date: Aug 2005 Location: Whiteland, Indiana
| Re: pactra backing black? Quote:
Just ran this for the first time today and it barely scratched it even though it's painted on the outside. She was definitely not easy on it. The only difference I noticed was that it was a lot more opaque so that when backing with it there is no chance of transparency. | |
pactra backing black? - Similar Threads | ||||
Tamiya backing Pactra??? | BrianP | Paint and Body | 3 | 03-09-2012 03:52 PM |
Backing with black tremclad | Caustic101 | Paint and Body | 1 | 08-11-2011 11:44 PM |
Pactra Lexan Paint - Black - Yellow - Metallic Blue | y2kgtp | Vendors Paint and Body | 0 | 03-18-2010 04:57 PM |
What pactra paint? | xxizzer421xx | Paint and Body | 1 | 05-29-2007 11:06 PM |
Non pactra/testors metalic backing? | hairba11 | Paint and Body | 1 | 05-03-2007 10:36 PM |
