Go Back   RCCrawler Forums > RCCrawler General Tech > Paint and Body
Thread: My boat paint job
Old 07-13-2012, 09:42 AM   #1
Fan of wheelspeed
Default My boat paint job
Im working on a boat, project Lime Disease. It's just a basher, nothing real nice. Mainly something for my nephews and I to run around the lake and get schooled by the hardcore racers, lol. Either way here she is.
Rustoleum Lime Green paint on top of flat white. I hit the tips with black and added the masks for flames.
I did my best in detailing the driver/navigator and the cockpits.
Next up, Ive got to polish the bottom so it glides thru the water a little easier. Any tips or ideas are always welcomed.
Hoosierdady is offline   Reply With Quote
Old 07-13-2012, 10:05 AM   #2
Default Re: My boat paint job
need's a trailer
richardgarrett56 is offline   Reply With Quote
Old 07-13-2012, 10:31 AM   #3
[QUOTE=Hoosierdady;3820700
Next up, Ive got to polish the bottom so it glides thru the water a little easier. Any tips or ideas are always welcomed.[/QUOTE]
The boat came out great!
For polishing, wet sand with with a very fine grit paper. I use 2000 for wet sanding that an auto body buddy gave me. Then lay 4 or so coats of clear, wet sanding between each.
When all is said and done wax and polish the sucker with a clear coat safe wax.
DickyT is offline   Reply With Quote
Old 07-13-2012, 10:58 AM   #4
Fan of wheelspeed
Originally Posted by richardgarrett56 View Post
need's a trailer
No trailor in the works man. Although yours looks damn nice.
Will do man. I've got to get some clear first. My can popped on me last night and shot clear coat all over my glasses and face. But I'll get her slicked up.
Old 07-13-2012, 11:17 AM   #5
0 0
romulus22's Avatar
As for the the bottom. I'm just going off memory and you may want to research this but I don't think you want a super smooth bottom. Something about the waters surface tension and surface contact on a smooth bottom is greater than a rougher surface bottom. Something like the golf ball affect.
romulus22 is offline   Reply With Quote
Old 07-13-2012, 12:06 PM   #6
~THE SCALE SHOP~
correct. when we raced offshore cats we actually sanded the bottom with 400 grit to help reduce surface tension
STANG KILLA SS is offline   Reply With Quote
Old 07-13-2012, 01:09 PM   #7
Fan of wheelspeed
I've read on other forums where they say that between 300-ish and 400 grit is the way to go too. The boat was originaly white, so I may just sand the hull (what cant be seen from above water) down to the OG finish. Some say polishing is a waste of time and gives no improvement on speed. I did read however, that certain paints repell water, and those are the ones to use. So my flat finish is going to kill me in the water. Im going to sand her down with 400 and call it good.
My boat paint job - Similar Threads
paint job crawler182 Losi Micro-Rock Crawler 7 04-03-2010 09:33 AM
My first paint job! 1428turbo Paint and Body 10 03-26-2010 11:14 AM
New XC-1 paint job joemomma95 Paint and Body 7 06-11-2009 05:10 PM
I need a paint job! BCCrawlerZ Paint and Body 8 02-17-2009 10:59 PM
Sv 27 New Paint Job Shaun (yota) Chit Chat 12 06-03-2007 09:21 AM
