Go Back   RCCrawler.com Bulletin Board > RCCrawler General Tech > Paint and Body
Thread: painting springs?
Old 08-04-2006, 04:43 PM   #1
Default painting springs?
what can you use to paint springs that wont peel or crack?
nitrorc2332 is offline   Reply With Quote
Old 08-04-2006, 07:35 PM   #2
Try powder coating them. Shouldn't cost to much.
Double J is offline   Reply With Quote
Old 08-04-2006, 07:37 PM   #3
Plastidip is a rubber compound you could dip them in they have clear, red,yellow,black. I think it would work. just my 2 cents
Gula is offline   Reply With Quote
Old 08-04-2006, 07:42 PM   #4
I've never tried it, but I think the paint that is used for painting lexan bodies might work. You can see how much a lexan body can flex without the paint chipping/flakeing off. Should work similar on springs, just keep the coats light.
Cake Eater is offline   Reply With Quote
Old 08-06-2006, 08:42 PM   #5
try your local fishing store. there is a product for powdercoating hooks and other tackle. it is pretty cheap and would probably work perfect. all you have to do is heat up your springs and dip them in the powder. it hardens pretty good but to be safe i would bake them in the oven to harden it even farther.
bulzeye is offline   Reply With Quote
Old 08-06-2006, 09:25 PM   #6
I've used good ole' Krylon Plastic Bond spary paint on mine for ever. I've never had a problem with it chipping or cracking due to stretching or flexing. Just clean them good with solvent, and scuff them with a brilo/scotchbrite pad for adhesion. The key is keeping your coats light and consistent.
All Out Racing is offline   Reply With Quote
Old 08-07-2006, 03:37 AM   #7
Hit 'em with a colored Sharpie.
Mad Scientist is offline   Reply With Quote
Old 08-07-2006, 04:14 AM   #8
CLODZIRRA's Avatar
It's all in the prep work... Clean them with thinner, scuff them throughly, clean them again, prime..paint using light coats.....let dry
CLODZIRRA is offline   Reply With Quote
Old 08-07-2006, 05:48 PM   #9
thanks guys. i think i am going to try krylon. i'll get back to tell yall how it worked.
Old 08-07-2006, 10:20 PM   #10
sharpie does work great, easy to touch up, and it's really shiny
-Dalton
hotrodzach is offline   Reply With Quote
