05-15-2013, 09:52 AM | #1 |
Pebble Pounder Join Date: Dec 2009 Location: limestone
| help / paint
My question is can you use automotive paint on tamiya hard shell bodys. My local paint shop can mix some cool colors and put them in a spray can. So someone out there in rc land let me know. Thank you!!
05-15-2013, 07:44 PM | #2 |
| Re: help / paint
bump
05-19-2013, 08:21 PM | #3 |
| Re: help / paint
ttt
05-19-2013, 11:08 PM | #4 |
I wanna be Dave Join Date: Mar 2013 Location: Minden
| Re: help / paint
not sure but I know for a fact home depot sells spray paint for plastic and primer for plastic in rattle cans,my local hobby shop sells Tamiya paint you can thin and airbrush, they got small rattle cans too. and clear coats too.
05-20-2013, 08:20 AM | #5 |
Quarry Creeper Join Date: Feb 2013 Location: Northcentral Wisconsin
| Re: help / paint
all I can offer is to try it on some scrap first to see if it will damage the plastic or not. You could go to your local auto parts house and get a small spray can of aftermarket touch up paint to try it with (cheaper and it is automotive paint - same chemical make up) |
05-20-2013, 08:44 PM | #6 |
| Re: help / paint
ttt
05-21-2013, 07:26 PM | #7 |
Quarry Creeper Join Date: Aug 2012 Location: Warrenton
| Re: help / paint
i have had luck on hardbodies with the duplicolor touch up cans. acrylic lacquer
05-21-2013, 07:39 PM | #8 |
Newbie Join Date: May 2013 Location: Farmington
| Re: help / paint
Automotive-grade paints will warp the day lights out of a hard body, unless you thoroughly prime it!
05-22-2013, 08:01 PM | #9 |
| Re: help / paint
bump
05-24-2013, 12:22 PM | #10 |
Pebble Pounder Join Date: Jan 2011 Location: Peace and Quiet
| Re: help / paint
I have seen it done, an old friend of mine works for an auto body shop and he painted his Trailfinder with PPG. Im not sure if Tamiya makes their bodies out of different material, but i wouldn't think its much different. Ive used Krylon on mine. That's a pretty aggressive paint.
05-24-2013, 12:35 PM | #11 |
Quarry Creeper Join Date: Jan 2012 Location: Mooresville, NC
Im an auto body tech an have been for 25+yrs. I use the same paint, we spray vehicles with on all my rigs. We have went waterborne a year ago and I use it as well. My tips, 1, scuff the body with 320 grit or red scuff pad. 2, prime the truck using a sandable aerosol primer 3, wetsand using 600 grit 4, spray your color of choice 5, **this is a must** put 2-3 good coats of clear over the paint. Even if your looking for a flat or dull finish, they make shinny, semi and flat clears in aerosol cans. This will protect the color on your truck. Most local paint supply places will mix your color and put it in an aerosol can for you too, just ask them about it. Good luck. Sent from the end of my fingertips |
05-28-2013, 01:17 PM | #12 |
| Re: help / paint
bump
05-28-2013, 06:30 PM | #13 |
Rock Crawler Join Date: Oct 2009 Location: Upstate NY
| Re: help / paint |
05-31-2013, 08:50 PM | #14 |
| Re: help / paint
bump
06-02-2013, 08:49 PM | #15 |
| Re: help / paint
night bump
help / paint - Similar Threads | ||||
Lexan Shell Paint Disaster, Paint Removal? | Big Tex | Paint and Body | 15 | 02-08-2012 12:58 AM |
Paint mask or easy way to paint houndstooth...ideas? | nascarkeith | Paint and Body | 3 | 01-10-2012 01:57 PM |
Paint: use bully dog paint adhesive | sdogg | Paint and Body | 0 | 11-06-2011 08:41 PM |
Auto Body paint or model paint in a can ??? | luv2ridemx | Paint and Body | 7 | 07-10-2011 07:40 PM |
