Go Back   RCCrawler Forums > RCCrawler General Tech > Paint and Body
Thread: Rc4wd yota body
Old 06-16-2013, 03:57 PM   #1
Default Rc4wd yota body
He guys i have an RC4WD yota lexen body for my scx10. My question to you guys is has any one else had problems with these bodies. Mine seems really thin. Having cracked in a few places from releativly minor bumps, bumps that my other truck would shrug off.
If anyone has had similar troubles how did u remedy it? Ive thought of doing like an internal bracing on problem areas but i dont know how super glue would go on the paint.
Any help appreciated
Sent from my GT-I9100 using Tapatalk 2
trukkracea is offline   Reply With Quote
Old 06-16-2013, 04:17 PM   #2
I myself back my most prone corners an bump spots with automotive AMAZING goop.. or like shoe goo.. squeeze it in the corners an smooth it down an smush it in, by wetting ur finger.. then let dry.. easy on paint and holds AMAZING!!
I also use it for holding light buckets in my body an wires to the inside walls of the cab.. its also waterproof too..
Hope it helps
winnerone23 is offline   Reply With Quote
Old 06-16-2013, 05:01 PM   #3
Cheers ill have to give it a go.
