Go Back   RCCrawler Forums > RCCrawler General Tech > Paint and Body
Thread: Where to buy Toyots Hi-Lux bodies??
Old 12-03-2013, 02:06 PM   #1
Default Where to buy Toyots Hi-Lux bodies??
Do I just have to source them from the Tamiya trucks, or is someone reproducing them??
Hotrodvw is offline   Reply With Quote
Old 12-03-2013, 02:16 PM   #2
Default Re: Where to buy Toyots Hi-Lux bodies??
You can buy them from anyone that sells tamiya replacement parts since that are available separate. Rc4wd also sells a very similar version.
Calderwood is offline   Reply With Quote
Old 12-16-2013, 07:56 AM   #3
Rc4wd sell a nice one....
redneck thug is offline   Reply With Quote
Old 12-16-2013, 09:05 AM   #4
The RC4WD mojave version also already has the dropped bed as well....
Sent from a broke down, overworked, and abused iPhone ....
scorpion0575 is offline   Reply With Quote
Old 12-16-2013, 07:09 PM   #5
The Mojave hilux body comes available in 3 different kit forms...
Yellow
Primer (yellow)
White
the cost to purchase those start at around $ 100.
and goes up progressively to $ 110. for the white styrene.
^ well... last I checked.
The only real differences between the Mojave and Tamiya Hi-Lux is...
Cost = (the Tamiya will cost nearly double to that of the Mojave)
Licensing = (Tamiya has auth./Lic... the RC4WD Mojave does not)
"TOYOTA" embossed tailgate = (Hilux/yes - Mojave/no)
Drop bed = (Hi-Lux/no - Mojave/yes)
Headlamp Assembly = (Hi-Lux round lamps - Mojave square lamps)
Interestingly... both bodies can share/swap parts.
ie: Don't like the square headlamps on the Mojave !?
The Tamiya Hi-Lux grille can be swapped in. (or visa/versa)
I have the Mojave body.
I prefer the Mojave's drop bed...
over the Tamiya Hi-Lux's tail gate molding.
and the Mojave's lower buy in.
TacoCrawler is offline   Reply With Quote
Old 12-16-2013, 08:48 PM   #6
Yellow
Primer (yellow)
White
^^^^ this ^^^^
When you combine parts of each the result is fantastic!
sgtbham is offline   Reply With Quote
Old 12-16-2013, 10:07 PM   #7
oops...
forgot to comment about options
The Mojave kit comes with two options
regarding the cab's rear firewall and window.
partial
= (w window flush to bedrail - cab bolted to bed)
full = (w window + full coverage rear cab wall)
this option allows the cab to be mounted independently
with or without mounting the bed.
a big plus if mounting to a tuber
not saying you can't scratch build one for the Tamiya Hi-lux body...
Many have... and with amazing results.
But all said...
the RC4WD Mojave body kit offers more options...
and did I say costs less !?
If it were critical to display the mfgr's namesake...
I think one could adhere some styrene pieces correctly
to spell out TOYOTA
or just slap on some vinyl stickers and call it a day
^ RC4WD sells those too !
Where to buy Toyots Hi-Lux bodies?? - Similar Threads
WHere to buy bodies saddlehorse Paint and Body 7 08-05-2011 06:10 PM
Does anybody know where i can buy bodies for my crawler? Riley808 Paint and Body 2 04-26-2010 10:06 PM
where can i buy older bodies ? nitrorube Paint and Body 5 01-29-2010 04:39 PM
where to buy bodies? yenrec Newbie General 3 08-30-2007 06:17 PM
Best place to buy to buy lexan bodies!! RYY Newbie General 2 11-24-2006 11:38 AM
