Go Back   RCCrawler.com Bulletin Board > RCCrawler General Tech > Paint and Body
Thread: Lexan body paint Q.....
Old 11-05-2006, 03:04 PM   #1
Default Lexan body paint Q.....
looking for that "flat black" look on the fender flares of a lexan body.
- Do I paint the outside of the body with flat black paint? seems like it would scratch and chip off very easily. If I do this- what type of paint shoud I use?
- Do I paint under the body black; then use a light grit sandpaper to "scuff up" the shiny body? I have tried this- looks OK; but I would like a more factory look.
- Any other options/opinions.
BTW: I am rattle canning this one so airbrush really isnt an option.
matt
cincy
mrpink is offline   Reply With Quote
Old 11-05-2006, 07:33 PM   #2
DIRTY SOUTH
Badd's Avatar
I paint the inside of the fenders and then the outside that way if it get chipped or scratched it will still be black under .
Badd is online now   Reply With Quote
Old 11-05-2006, 07:48 PM   #3
was thinking of that too... any ideas on what type of paint? I have Testors flat black hobby spray- will that work/stick? Maybe BBQ high heat black from a hardware store (just thinking it may be more durable.).
thanks.
matt
cincy
Old 11-05-2006, 11:17 PM   #4
I'm a stupid C U N T!
slobin3d's Avatar
you have to use a paint designed for lexan or it will flake off when flexed. there are several RC paints out there. most of which are flat and rely on the clear body for the Gloss look they have.
Pactra, faskolor, tamiya to name a few
slobin3d is offline   Reply With Quote
Old 11-07-2006, 02:18 PM   #5
[HOONIGAN]
Wrecker's Avatar
You could paint the inside of the body and then sandblast the outside. Just mask off the the rest of the body that you want to stay shiny. If you can get acssess to a sand blaster. I haven't tried it, but it sounds like it will work.
Wrecker is offline   Reply With Quote
Old 11-07-2006, 10:00 PM   #6
oddly enough i do have a blast cabinet in my garage- but I would think that was be a bit... lets say- dangerous. hold it for one sec too long and now you have a hole where the fender flare used to be. I am trying the outside the body paint method. I will post pics when done.
matt
cincy
Old 11-08-2006, 06:31 AM   #7
Plastic Dip the Outside of the Fenders.
Old 11-08-2006, 07:23 AM   #8
Colt Python/SR9c
TwistedCreations's Avatar
Found THE ticket for realistic flares
TwistedCreations is offline   Reply With Quote
Old 11-08-2006, 07:11 PM   #9
odd.. i was just thinking the same thing. nice. WILL DO!!!
matt
cincy
Old 11-16-2006, 09:07 AM   #10
final product. now all I need is a good chassis to mount it on.
matt
cincy
