11-03-2014, 05:11 PM | #1 |
Pebble Pounder Join Date: Nov 2011 Location: Muskoka, Ontario
| Hardbody paint removal questions.
My question pertains more to the body than the paint. I just got an s10 hardbody and I'd like to strip the paint. My question is does anyone know what these bodies are made of? I don't want to soak it in brake fluid and find out it reacts with this type of plastic. Brake fluid works great on Tamiya bodies but I've yet to try it on any different types like a NewBright or this one(radio shack I believe). Is brake fluid safe on all plastics?
11-03-2014, 07:14 PM | #2 |
I wanna be Dave Join Date: Mar 2013 Location: Minden
| Re: Hardbody paint removal questions.
no it is not, I used brake fluid on a RC4WD Toyota Hardbody, too remove two layers of Green Camo top coat paint and two layers of different colors of thick non sand able primer. And you can see where the brake fluid harden the abs plastic and made it brittle and now got cracks in it and it discolored the Yellow truck body. I don't care cause I dinged and dented up the body and added layers of rust, the harden and discolored areas look good. It blends into the beaten up Truck theme. Maybe the ABS Plastic on my Truck body is old I bought it used and was stripped a few times before I got it |
11-03-2014, 07:36 PM | #3 |
| Re: Hardbody paint removal questions. |
11-03-2014, 08:27 PM | #4 |
is it painted on the inside, pick a small spot and use a little brake fluid on the inside like under the bed or inside the fender and see what happens. Here are some pictures of the Truck now see how the plastic is dull looking not shiny like a new Toyota Hard Body would be and it been sanded and Scotch Bright Padded too rough it up so the rust colored paint would stick better The dull sections make it look old and rusty and dirty and looks it has been worked over Last edited by kgb424; 03-25-2015 at 05:35 PM. |
11-04-2014, 02:00 AM | #5 |
MWRCA'er Join Date: Apr 2004 Location: Machesney Park IL
In my experience it made my Bruiser body brittle and crack easily. Hard to say what to use as there is nothing designed as a remover. Personally I'd sand the thick areas off with sand paper then hit it with primer sand and paint.
11-04-2014, 09:23 AM | #6 |
Rock Crawler Join Date: Sep 2009 Location: Spring, Texas
I just used Citristrip spray (found at Wal-Mart) to remove several layers of paint from a Land Rover D90 body that had original plastic and some Styrene sections. It worked well on both plastics, but I noticed that the areas where it was left on for too long softened the top layer of the ABS just a bit. Once everything was cleaned off, washed and it had a day to dry out it sanded smooth. Citirstrip is supposed to be the safest thing to remove paint from plastic, so nothing is perfect I guess. At least it did not harden the plastic or make it brittle. I hate painting. Removing paint so that I can paint again is like torture. Good Luck! Last edited by Alpha Male; 11-05-2014 at 09:21 AM. |
11-04-2014, 10:26 AM | #7 |
Rock Crawler Join Date: Jul 2011 Location: USA
From the picture it looks like you already have it sanded pretty good. I would just paint over that.
11-04-2014, 04:54 PM | #8 | |
Citristrip eh? never heard of it. I will check out wally and see if they have it. I heard that graffiti remover works as well as oven cleaner. Im going to try the oven cleaner first and see what happens. Quote:
11-04-2014, 07:23 PM | #9 |
I know oven cleaner works to remove chrome, Cause I used some on the front bumper on my Toyota build it was chromed when I got it, I like it black better. It should be ok to remove paint it may take a few cans and lot of scrubbing, I keep old toothbrushes just for use of chemicals instead my fingers and hands. Wally World sells three little hand brushes in a pack there is a nylon one, one with brass bristles and one with steel bristles I have also used those too. Last edited by kgb424; 11-04-2014 at 07:27 PM. |
11-04-2014, 07:25 PM | #10 |
Newbie Join Date: Jul 2013 Location: Modesto, Ca
Oven cleaner can be used to remove paint. What I use is Super Clean Degreasser. I usually buy it by the gallon at Wal Mart. I also use it to strip the paint on my scale plastic models.
11-05-2014, 09:23 AM | #11 | |
| Re: Hardbody paint removal questions. Quote: That's a neat looking scale scene you have going on there! Home-made cinder blocks? | |
11-05-2014, 09:26 AM | #12 |
| Re: Hardbody paint removal questions. I used Super Clean to remove the chrome from a few plastic parts, but it never occured to me to use it for paint remover, lol. |
11-05-2014, 12:20 PM | #13 |
So I tried oven cleaner and it did not work. Next up is superclean then citristrip if i can find it. I think this thing is painted with tremclad rust paint for metal, cause its sure is tough. Thanks Alpha, the cinder blocks are 3d printed. |
11-05-2014, 12:56 PM | #14 |
11-05-2014, 03:44 PM | #15 |
I have also used Simple Green to remove paint, at full strength and it let soak, it works on certain paints good and not so much on some. its cheap and easy to find
11-08-2014, 06:17 AM | #16 |
11-08-2014, 08:40 AM | #17 |
It may take awhile but it will come off, it will come off pretty easy once the brake fluid start breaking done the paint, that's why I use brush it helps loosen the paint.
Hardbody paint removal questions. - Similar Threads | ||||
Lexan Shell Paint Disaster, Paint Removal? | Big Tex | Paint and Body | 15 | 02-08-2012 12:58 AM |
Hardbody paint removal | ser3100 | Paint and Body | 3 | 07-24-2010 08:21 AM |
Paint removal | aashu | Paint and Body | 9 | 10-13-2009 04:48 AM |
Paint removal help | spot me 2 | Paint and Body | 2 | 05-07-2008 07:04 PM |
