Go Back   RCCrawler Forums > RCCrawler General Tech > Paint and Body
Thread: need info re modifying a Wraith chassis
Old 06-05-2014, 03:20 AM   #1
IPT
Default need info re modifying a Wraith chassis
Hey guys, I'm learning and pretty new at this but diving in deep. I want to modify a Wraith chassis. Maybe Narrow the center, widen the rear to take another body. Maybe lower the overall height of the cage. I will look at the stock kit and find the proper size Tap so can drill and thread some new holes.
Looks like people also just use links. What are you guys using to match the tube for the Wraith chassis? Anyone just cut it and epoxy it back? Maybe drill and use a metal pin or dowel for strength?
I'm new so just throwing out my initial thoughts. Been reading tons of threads but thought this might fast track me to some answers. I know I can get some metal and braze, but that seems like a little more expense and above my skill as of now.
IPT is offline   Reply With Quote
Old 06-05-2014, 05:57 AM   #2
Default Re: need info re modifying a Wraith chassis
When I modified my old Honcho cage, I used M3 x 16mm set screws. Drilled and screwed in to one side, and drilled and used CA glue for the other side.
rob5059 is offline   Reply With Quote
Old 10-21-2014, 08:01 PM   #3
I narrowed the front. After some cutting,heating, and bending I think it turned out great. Back is next
Got back done now. Did you get started on yours yet?
gwcrawler is offline   Reply With Quote
need info re modifying a Wraith chassis - Similar Threads
need wraith axle info...... bob1961 Axial Wraith 2 01-21-2014 07:02 PM
need some info help on my wraith rswarrior Missouri 1 06-09-2013 11:29 AM
Modifying stock chassis mltxj9889 HPI Wheely King 22 04-14-2010 05:44 PM
chassis info looneybin Chit Chat 5 02-21-2007 07:57 PM
Need some chassis help - info mr.maxx Newbie General 1 03-12-2006 09:02 AM
