05-15-2016, 06:34 PM | #1 |
Newbie Join Date: Jan 2016 Location: Arizona
| Tips? - reamer and clean body mount holes
Does anyone have tips on using the reamer and creating clean body mount holes? I find there is a lot of material pushed inside the body, leaving a rather jagged hole. I trim the jagged bits, but it's still not real clean. Thanks. |
05-15-2016, 07:46 PM | #2 |
| Re: Tips? - reamer and clean body mount holes
Cut from both sides. Start your ream from one side, then flip and cut from the other side, little at a time until you get near the right dimension. Most hobbyshops sell tube sanders (sandpaper glued around a cardboard straw) in various sizes, to clean up the holes.
05-15-2016, 08:36 PM | #3 |
RCC Addict Join Date: Jan 2016 Location: Kelowna, BC
I've only ever done about 3-4 bodies but I've never used a reamer for making post holes. A 1/4" drill bit has always worked and leaves nice clean holes.
05-16-2016, 08:56 PM | #4 |
Quarry Creeper Join Date: Feb 2015 Location: Corpus Christi
Yep I use drill bits. Fast and clean. Sent from my XT1585 using Tapatalk |
05-17-2016, 06:37 AM | #5 |
RCC Addict Join Date: Dec 2009 Location: Laceys Spring, Alabama
| Re: Tips? - reamer and clean body mount holes |
05-17-2016, 11:55 AM | #6 |
If you're getting really jagged holes with a body reamer, it sounds like you're taking too big of a bite. Go slow and take light cuts and you should be fine. I only go in from one side and never have problems with burrs. Good luck! |
05-18-2016, 01:14 PM | #7 |
Good tips. I'll go slower and try some sanders to finish things up. I would think the drill bits would twist up the lexan and turn areas white. I'll try it on some scrap bits first. Thanks. |
05-18-2016, 01:39 PM | #8 | |
| Re: Tips? - reamer and clean body mount holes Quote:
As someone said, don't force it in too fast as this can make holes jagged too. | |
05-18-2016, 02:54 PM | #9 |
Tips? - reamer and clean body mount holes - Similar Threads | ||||
any handy way to mount body without drilling holes? | e32lover | Paint and Body | 7 | 08-13-2013 11:05 PM |
How to mount body with no body clips or holes? | ProfitOfDoom | Axial SCX-10 | 9 | 04-16-2013 05:03 PM |
Proline Rockstar body mount holes for Gc3 | droopmodmrc | Losi Mini-Rock Crawler | 0 | 05-01-2010 10:23 AM |
Body Mount Holes | WarTrader | Paint and Body | 2 | 02-09-2009 05:56 AM |
