03-06-2017, 08:00 AM | #1 |
Quarry Creeper Join Date: Aug 2014 Location: holland
| body mounting options.
For the mounting of the body; I do have an issue, or dilemma you might say. It's about this rig. Option 1: Body in one piece Option 2: Body separated Choices… choices.. The plan is to place the battery in backrest of the front seat. The rear of that cab is open so the area is fully accessible (If option 2 is applied) Advantages option 2 (over option 1): - I can mount the cab part semi-permanent. I don’t need access there that often. - Wiring of the (front) lights doesn’t need to go all the way to the back past the hinge area. - Hinge and locking mechanism take less stress (in case of rollovers etc) - Cage mounting frame under the bed can be used for the locking mechanism. It also has its downsides: - Keeping it in one piece makes it all a bit simpler - Having to hack into a perfectly good body (bumper aside) - Styrene work of a constructive nature are required (might sound silly, but I’m an amateur in that area) - Risk of body part misaligned during construction and/or over time I’m leaning towards option 2. Can someone point out any examples of the split option and its mounting? Especially to keep the parts aligned. Input is welcomed. |
body mounting options. - Similar Threads | ||||
Battery mounting options | sickcivic95 | RC4WD Trail Finder 2 | 2 | 04-23-2014 09:20 PM |
Gopro mounting options | chopan84 | Axial Wraith | 7 | 11-16-2013 10:37 AM |
4 Link mounting options | twisted | Vaterra Twin Hammers | 2 | 07-15-2013 11:57 AM |
Hilux mounting options | brianw | Axial SCX-10 | 7 | 08-30-2011 12:55 PM |
Trans mounting options? | BlueMonster | Tamiya TLT Crawlers | 7 | 09-26-2006 01:17 AM |
