Go Back   RCCrawler.com Bulletin Board > RCCrawler General Tech > Paint and Body
Thread: removing paint from hard body
Old 02-03-2007, 12:10 AM   #1
chino63's Avatar
Default removing paint from hard body
This pertains to scale builds since comp tlt's rarely use a hard body so, mods, move if necessary. I've looked but i can't find a thread with any good info. What do you all use to strip paint from a hard body? I have tried a few things including brake fluid, all with less than satisfactory results until now. What i found at the lhs was this stuff called Scalecoat II ($9.95 per pint). Holy s#it!!! this stuff works way fast and does the cleanest job of removing paint. It is specifically designed to remove paint from plastics and can be reused. Definately worth the money in my eyes. I stripped the paint off two bruiser cabs and a bed in less than an hour. This included finding a ziplock big enough, swapping parts out one at a time and scrubbing with a brush lightly to remove the stubborn spots, rinsing with hot water and cleaning them with soapy water to make sure they were squeaky clean. Completely done all ready to repaint! Just thought i'd share and hopefully help some of you out.
chino63 is online now   Reply With Quote
Old 02-03-2007, 01:32 AM   #2
Official Scale Nazi
pigeonfarmboy's Avatar
Cool Dean thanks. Nail polish remover works too but just takes F-O-R-E-V-E-R
pigeonfarmboy is online now   Reply With Quote
Old 02-03-2007, 02:26 AM   #3
chino63's Avatar
This stuff is awesome, like i said, completely stripped and ready to go in an hour!
Old 02-03-2007, 03:18 AM   #4
minijosh's Avatar
I always use eazy off.
minijosh is offline   Reply With Quote
Old 02-03-2007, 07:42 AM   #5
The brake fluid technique worked for me, I stripped a Jugg body with about thirty layers of paint in a day with some DOT4.
Hellisforheroes is offline   Reply With Quote
Old 02-03-2007, 08:44 AM   #6
Haters gonna Hate
1BadJeepBruiser's Avatar
I have always used "castrol super clean and degreaser" or AKA purple power...but lately it doesnt seem to be working as good, the color of the stuff changed and I think they may have changed the formula.
Dean, Im going to copy this thread this into the paint and body work section, I think its a good place for it too this way when people search I think that forum would be the best place to go
Old 02-03-2007, 09:57 PM   #7
OG Green Meat Star Man
young_version's Avatar
This should clear up any confusion, it seems that this guy makes models and any of you that are familiar with model brands should adapt to this writeup pretty well, if not the guy says which chemicals to stay away from. Here you go:http://www.ndrr.com/rmr_faq/Models/Paint-Stripping.htm
oh BTW for acrylic: OXICLEAN and warm water works pretty well too. sounds kind of nuts but it works.
young_version is online now   Reply With Quote
Old 02-03-2007, 10:58 PM   #8
Get off my lawn!
microgoat's Avatar
X2 on the Easy-Off. Be sure to get the yellow label, with all the toxic fumes.
microgoat is offline   Reply With Quote
Old 02-04-2007, 12:06 AM   #9
what about paints designed for plastic? ive been having a bugger of a time removing krylon fusion
Got Rocks? is offline   Reply With Quote
Old 02-04-2007, 12:41 AM   #10
i know oven cleaner will eat the chrome off plastic rims might work on paint why not just use lacquer thinner
andrewmp6 is offline   Reply With Quote
Old 02-04-2007, 12:44 AM   #11
Default Wish I would have known
Wish I would have known this about 4 years ago. I tried to take paint off of a Tamiya jeep wrangler hard body(extremly rare and expensive when you do find them). I was told I could use Decal and Paint remover in an aerosol can. WRONG ANSWER. I had to scrap the whole thing. Talk about a hard lesson learned.
rcnut38 is offline   Reply With Quote
Old 12-09-2007, 11:05 AM   #12
is this the one your refering to?
how about this?
i am going to strip the paint on my bruiser body but i cant find castrol superclean or purple power here so i was wondering which one of those in the pics works.
lanzky1008 is online now   Reply With Quote
