05-19-2020, 02:32 PM | #1 |
Pebble Pounder Join Date: Oct 2010 Location: washington
| Elmer's glue instead of liquid mask.
Who's done it? And does it work?
05-19-2020, 03:46 PM | #2 |
RCC Addict Join Date: Nov 2017 Location: Austin Texas
| Re: Elmer's glue instead of liquid mask.
Liquid mask stays fairly pliable/ flexible after it dries... making cuts pretty easy with an xacto. Elmer's dries much more rigid and especially in thicker areas, may not cut as easily. Add to that, regular Elmer's becomes more brittle after drying... cracks easier and lifts easier. Maybe using Elmer's in a pinch as long as the masked/ graphic/ cutting area isn't too intricate... might work. But I'd steer clear of it in most cases.
05-19-2020, 03:47 PM | #3 |
Rock Crawler Join Date: Apr 2014 Location: Portland
I think it is about the same stuff.
05-19-2020, 03:52 PM | #4 |
I wanna be Dave Join Date: Sep 2019 Location: US
Simple answer:. DON'T try it...you'll be sorry. ~ More peace, love, laughter & kindness would make the world a MUCH better place |
05-19-2020, 06:50 PM | #5 |
Newbie Join Date: Apr 2020 Location: San Diego
Lexan bodies (especially crawler bodies) are getting expensive, easily 50-60. Don't risk ruining a body or spending hours trying to correct it just to save a few bucks.
05-19-2020, 07:04 PM | #6 |
Yes Elmers, or any of the white glue variants work, but as stated are brittle, so they work on hard surfaces,primarily for long cuts. Stick with the flexible ones on lexan. Where they can work well, is to repair tape lines in inside corners for example. Another tool , but I’ll stick with Bitty. Hang up and Drive |
05-19-2020, 07:05 PM | #7 | |
I wanna see somebody spray a body with Elmer's and then try to peel it off... I don't know if it'll work, but I'd be shocked if it does. EDIT: Quote:
05-19-2020, 08:54 PM | #8 |
The paint holds it together, it works poorly as it won’t hold an edge with any radius.....better as a patch, although I do paint bitty over tape that needs extra cover Aileens tacky works better Hang up and Drive |
05-19-2020, 10:08 PM | #9 |
| Re: Elmer's glue instead of liquid mask. Interesting. It makes sense that it doesn't hold clean edges.
Elmer's glue instead of liquid mask. - Similar Threads | ||||
Liquid mask | jeeptec | Axial SCX10 II | 4 | 01-17-2019 06:02 PM |
Liquid mask | silverside83 | Paint and Body | 4 | 01-02-2013 09:43 PM |
Liquid mask? | Onebdgti | Paint and Body | 5 | 01-02-2012 12:00 PM |
Liquid mask: First try. | RIG_RIDER | Paint and Body | 15 | 05-12-2011 10:13 AM |
liquid mask | foolish 1 | Paint and Body | 10 | 09-06-2010 04:36 AM |
