Go Back   RCCrawler Forums > RCCrawler General Tech > Paint and Body
Thread: Window netting
Old 12-30-2020, 12:09 PM   #1
Question Window netting
Hi,
I'm after painting a window safety net effect on a lexan shell, anyone done it or have any pointers.
Cheers
Jim
Jimplops is offline   Reply With Quote
Old 12-30-2020, 01:50 PM   #2
Default Re: Window netting
Originally Posted by Jimplops View Post
Hi,
Cheers
Jim
On the outside or the inside?
Painting it on the inside would leave it looking glossy, so I'd do something on the outside using a matt/satin paint.
Not sure how you would mask it to be honest because you're actually wanting to mask a lot of little squares rather than a net.
Might be better to make something - depending on the scale you could use 1/8 or 1/4 black ribbon? I started doing something similar a while back for a 1:8 scale window net using a wire retainer around the edge and ribbon in a cris-cross pattern but got frustrated and stopped.
OutLore is offline   Reply With Quote
Old 12-30-2020, 02:17 PM   #3
Go Buckeyes!
B-MOW71's Avatar
If you want to add netting instead of painting, I found this window netting on eBay. It is LEGO 10x10 netting. Super cheap and looks very scale.
B-MOW71 is offline   Reply With Quote
Old 12-30-2020, 08:43 PM   #4
I've used the mesh from produce bags in the past for window nets.
Sent from my moto g(7) power using Tapatalk
Screwfly is offline   Reply With Quote
Old 12-31-2020, 08:09 AM   #5
Thanks for the replies, may go down the route of using net on the outside now it's been suggested ������
Window netting - Similar Threads
Driver safety netting. flarezfx Scale Accessories 13 02-28-2014 02:15 AM
Window Flange? kc092755 1.9 Scale Rigs 0 06-16-2011 04:36 AM
open PM in new window, opens in same window. obijuan Comments, Suggestions, and Help 8 08-07-2007 12:36 PM
