05-19-2021, 12:02 PM | #1 |
Newbie Join Date: Apr 2021 Location: Baltimore
| help cutting lexan
due to medical conditions cutting lexan bodies is hard, i can do it but because i have trouble keeping my hand steady, its hard to cut it clean and correctly. any suggestions or ideas would be great |
05-19-2021, 12:16 PM | #2 |
I wanna be Dave Join Date: Sep 2019 Location: US
| Re: help cutting lexan
One that I've read, and am very interested in trying, doesn't involve scissors at all. Using an X-Acto knife (or surgeon's knife, as I prefer), you 'score' your cut lines around the entire body (and other areas, when/where needed), and then 'bend' there level to "pop" the excess off. ~ More peace, love, and kindness would make the world a much better place |
05-19-2021, 12:46 PM | #3 |
Quarry Creeper Join Date: Jan 2021 Location: in the Canyon
Cut it as rough as you want-- then finish all of the edges with a sanding drum on a Dremel. It's a lot easier to keep the tool steady when you can use both hands. I have quite steady hands-- and this is how I do all of my bodies. The scoring trick takes VERY steady hands.
05-19-2021, 12:58 PM | #4 |
I use a sharp carbide scribe, scoring all lines, I also add straight relief lines. Then I don’t cut anything, just bend and tear. A sanding drum on a Dremel or drill to finish as needed Hang up and Drive |
05-19-2021, 03:39 PM | #5 |
Quarry Creeper Join Date: Dec 2013 Location: The Garden State, North of I-80
Can you mark it and get someone else to cut for you?
05-19-2021, 06:00 PM | #6 |
Check out the sticky at the top of the Paint and Body section, How-To:Cutting with thread |
05-31-2021, 11:53 PM | #7 |
Newbie Join Date: May 2021 Location: Bellingham
I cut mine about 1/4" to 1/8" away from the body line, and then use a drum sander on low speed on my dremel to get the lines perfect.
06-01-2021, 09:53 AM | #8 | |
RCC Addict Join Date: Jan 2016 Location: Kelowna, BC
| Re: help cutting lexan Quote:
The first line that you score/scratch can be done really lightly to help you make sure it's in exactly the right spot and then your knife will naturally follow the groove that you started. Score it several times so it's quite distinct and then bend it to crack the scored line apart, once the crack is started you can just keep tearing all the way along your scored line - be careful not to tear past the end of what you scored. The most important part of success with this is making sure that the blade you're using is sharpsharpsharp. I always use an Olfa type blade and snap a section off to ensure I've got a nice sharp tip corner. | |
help cutting lexan - Similar Threads | ||||
Lexan cutting help... | MonsterAnt | Paint and Body | 7 | 02-04-2013 02:19 PM |
Cutting lexan body | Bogncrawl | Paint and Body | 5 | 11-02-2012 05:04 PM |
lexan cutting | dman10 | Paint and Body | 6 | 05-05-2011 03:43 PM |
lexan cutting | chivas72 | Paint and Body | 7 | 03-27-2007 02:10 PM |
Cutting lexan with a bandsaw | AdamF | Chit Chat | 1 | 01-16-2005 05:16 PM |
