02-27-2007, 05:59 PM | #1 |
Rock Crawler Join Date: May 2004 Location: delavan
| backing paint
ok this is my firts time using this paint i am using rc261 pearl purple will i need to back this if so what should i back it with i asked the guy at the hoppy shop but he said he did not know if it needed to be over coated thanks |
02-27-2007, 06:01 PM | #2 |
I'm a stupid C U N T! Join Date: Jun 2005 Location: In the Garage!
if you want a darker finish back it with outlaw black or metalic, the flake will show through if youre coats arent to thick or if you want a lighter brighter finish, indy silver |
02-27-2007, 06:09 PM | #3 |
awsome thanks looks like i will be heading back to the hoppy shop tommorow
02-27-2007, 06:11 PM | #4 |
I would recomend doing a couple of test shots on the bodys flashing to get an idea of what its going to look like, that way you have an idea of what you want before you commit to the whole truck P.S. i trim my body before painting to prevent scratching all that pretty new paint and so you can mark youre body holes while you can still see were they go |
02-27-2007, 06:26 PM | #5 |
yes its all trimmed up i just sprayed the first coat of paint will let that dry tommorow i will finish it up thanks
02-27-2007, 06:53 PM | #6 |
Pebble Pounder Join Date: Jan 2007 Location: Livonia
If this stuff goes on Translucent, don't back it with Pactra Metallic Black... You'll get a real nasty color out of it... If it's translucent, back it with Pactr Indy Silver and you'll get a rich "Grape" purple color out of it. Example: I used "Pactra Candied Red" on this, then backed it with Pactra Black... Bad Call. |
02-27-2007, 06:53 PM | #7 |
Rock Crawler Join Date: Aug 2006 Location: sleeping in my truck!
i did a truck awhile back with that same color, only thing i shot some blue pearl behind it and then with backed it all with silver. looked awesome, just like a dark purple with alittle bit of blue in the sunlight. i'll see if i can dig up some pics.
02-27-2007, 06:56 PM | #8 |
I did a suby body with pearl blue and met. black and it turned out looking almost exactly like Blue Ridge Pearl there might be a bit of technique involved, and the proper color matching:-P |
02-27-2007, 07:44 PM | #9 |
yeah i plan to back it with the indy silver but for now here is what i got |
02-27-2007, 08:22 PM | #10 |
| purdy... should look killer when its done. Ive always been a fan of purples
02-28-2007, 03:19 AM | #11 |
nice color |
02-28-2007, 07:20 AM | #12 |
Rock Crawler Join Date: Feb 2006 Location: Warner Robins
pearl purple backed with silver will come out pink if not coated thick enough. I'd back it with candy grape
02-28-2007, 12:22 PM | #13 |
Quarry Creeper Join Date: Aug 2004 Location: HP lounge
I've done several bodies with True Blue Pearl backed with Indy Silver, turns out great. Even better is misting a very light coat of Silver on first, then laying down the blue.
02-28-2007, 04:54 PM | #14 |
Newbie Join Date: Feb 2007 Location: redsand
Nice color !! Also I like the bug body .
02-28-2007, 06:04 PM | #15 |
Quarry Creeper Join Date: Jan 2005 Location: Westchester
I'd recommend backing everything with white. It causes colors to pop more,w here silver kind of tones it down. If you plan on backing, make sure your coats are even or thick enough. |
03-01-2007, 09:45 AM | #16 | |
Rock Crawler Join Date: Nov 2005 Location: Fremont/Newark, California
