Go Back   RCCrawler Forums > RCCrawler General Tech > Paint and Body
Thread: grave digger
Old 03-08-2007, 05:35 PM   #1
Default grave digger
do they have one that will fit the WK's stock wb or close to it. i cant find one. hard or lexan.
cammok5 is offline   Reply With Quote
Old 03-08-2007, 05:38 PM   #2
What's the WB on a WK? I've seen 1/8 and 1/10 scale ones...
FossilJunkie is offline   Reply With Quote
Old 03-08-2007, 05:51 PM   #3
WHEELBASE: 238.8mm (9.4in.)
Old 03-08-2007, 06:03 PM   #4
That is going to be really hard to find for that short of a WB. Gravedigger has run anywhere from a 13-152" WB, so 9.4" would almost be 1:15 scale (around there. Most likely you are going to either lengthen your WB, or pick out something else! If you shoot for somewhere around a 13-15" WB, then a 1:10 scale body would work well!
