05-17-2007, 07:35 PM | #1 |
Pebble Pounder Join Date: Jun 2006 Location: under my truck
| i made a oops
can anyone tell me a good way to strip a lexan body i just made a big fawkin mistake and i can get to anywhere to get anything to clean it am i in a bad spot or is there something i can do when it dries? the paint is not on thick just few light coats
05-17-2007, 07:47 PM | #2 |
Rock Crawler Join Date: Feb 2006 Location: Warner Robins
Dot 3 Brake fluid will remove the paint. Never tried it while it was still wet but should work. Take a rag and soak it with Dot 3 then just wipe the paint off. Once the body looks clean of all paint, (use a white background to check) Wash the body with warm water and dish soap. It should be squeaky clean. I'd recommend using rubber gloves. I used brake fluid to remove the factory paint on this one so I could paint it purple: |
05-17-2007, 07:47 PM | #3 |
Built, not bought Join Date: Oct 2004 Location: Gresham
What type of paint?If it's faskolor,just wash it before it dries.
