07-13-2007, 09:03 AM | #1 |
Adilynsdad too! Join Date: May 2004 Location: G ville
| Stripping paint from styrene?
What works without damaging the styrene? Also, what is the best primer to use on stryrene bodies?
07-13-2007, 09:45 AM | #2 |
Pebble Pounder Join Date: Nov 2005 Location: Back in MICHIGAN
i think you could use easy-off oven cleaner, get the blue can first and test it, if not get the yellow can.
07-13-2007, 11:27 AM | #3 |
I had the hottest girlfriend at the MSD Nats Join Date: Dec 2006 Location: Hecho en Tejas
i just use automotive primer. or you can get a rustoleum primer specifically for plastics. i havent really seen a difference in adhesion.
07-13-2007, 11:58 AM | #4 |
I wanna be Dave Join Date: May 2006 Location: Arlington, VA
forget the blue can, easy off yellow, works great. heres how i do it, get a nice thick contractor grade trash bag, place body in bag, soak down body with easy off, close bag off, set in the sun. check it in 12 hours, spray more easy off, repeat until paint is gone. also helps if you rub with a stiff nylon bristle brush, or even a hard toothbrush. just dont give it back when your done. other people have said a wire brush but i'm not taking that chance!
07-13-2007, 01:44 PM | #5 |
naw i wont use a wire brush unless you want to sand the body smooth.
07-13-2007, 02:44 PM | #6 |
Pebble Pounder Join Date: Jan 2006 Location: Knoxville,TN
I use the yellow can,It my take a few coats depend on how many paint jobs it has had. Then I use a old tooth brush and warm soapy water. |
07-13-2007, 04:51 PM | #7 |
silver is one of the hardest colors to remove.
07-13-2007, 06:08 PM | #8 |
07-13-2007, 06:14 PM | #9 |
07-13-2007, 06:18 PM | #10 |
dosnt so much burn as eats your skin away. i was "thin skinned" in a few places on my fingers for awhile last body i did. dish gloves are cheap.
