08-21-2007, 08:28 PM | #1 |
Quarry Creeper Join Date: Jan 2006 Location: Siler City, NC
| Any ideas on how to strip paint?
And yes I did search but did not come up with any good answers. I dont want to use oven cleaner and dont know of any other ways. It looks like I painted the body 3 or 4 times. I have had it for over 10 years so I dont remember exactly how many times I painted it. The body is kinda rough, I might just do it the old fashioned way. Last edited by talonted1990; 08-21-2007 at 08:37 PM. |
08-21-2007, 09:18 PM | #2 |
Rock Crawler Join Date: Apr 2006 Location: I hope you SHUT UP!!!
try paint thinner or brake cleaner. I used gasket remover for my tuber but I think that will melt your plastic. |
08-21-2007, 10:32 PM | #3 |
Moderator Join Date: Jan 2004 Location: chicago
why not oven cleaner? all you need is a trashbag and some rubber gloves. |
08-21-2007, 11:46 PM | #4 |
Oppan Gangnam Style Join Date: Jun 2005 Location: Shingle Springs
08-22-2007, 02:06 PM | #5 |
I lost my vendor privileges Join Date: May 2006 Location: TOP OF THE HILL
cool. is that going under the new chassis?
08-22-2007, 02:10 PM | #6 |
I wanna be Dave Join Date: May 2006 Location: Arlington, VA
80 grit and a rotary sander, it'll get it off.
08-22-2007, 02:14 PM | #7 |
Quarry Creeper Join Date: Jun 2007 Location: Del mar
Sand blast it. I did it on my clod took the paint right off and left a smooth paintable surface. |
08-22-2007, 02:18 PM | #8 |
Rock Crawler Join Date: Apr 2007 Location: LaSalle
^^ x2 I seen these little setups at harborfreight. They looked like little airbrush kits but they were for sandblasting. I think they were in the range of $20 or so.
08-22-2007, 07:30 PM | #9 |
I had the hottest girlfriend at the MSD Nats Join Date: Dec 2006 Location: Hecho en Tejas
sand is very abrasive, why not soda blast?
08-23-2007, 07:15 AM | #10 |
Rock Stacker Join Date: Nov 2006 Location: 1/2 way between Cleveland and Columbus
I wouldn't recommend brake cleaner. It will more than likely eat into the plastic and make it sticky. I know you said you didn't want to, but oven cleaner seems to work the best.
08-23-2007, 08:19 AM | #11 |
Quarry Creeper Join Date: Jun 2007 Location: Calgary, Alberta
Easy off oven cleaner takes off paint AND chrome from plastic
08-23-2007, 01:01 PM | #12 |
Rock Crawler Join Date: Feb 2006 Location: Warner Robins
use brake fluid to just wipe the paint off. Search for Brake Fluid. |
08-23-2007, 05:09 PM | #13 | |
I want to use it if I can clean it up some. I might try that. I have a sandblaster and 2 five gallon buckets full of sand. | |
08-23-2007, 05:49 PM | #14 |
Easy-off is easy man. It comes off in seconds. Just rinse with warm water and an old toothbrush. I stripped the chrome off my clodbuster wheels in about 5 mins.
08-23-2007, 05:58 PM | #15 |
Then, if you want the surface to be like glass, blast it with Corn Starch. It may look like it is'nt doing anything but it is if the air PSI is high enough. 140 Psi works well with corn starch. Renslipevol, he has an exploritive Daughter, he does'nt want chemicals. |
08-23-2007, 06:55 PM | #16 |
your LHS or Tower will have Polly S, EASY-LIFT-OFF. Safe on plastic and works like a champ |
08-26-2007, 02:24 PM | #17 |
Thanks for the help. I started sanding by hand because I have not had time to use the sandblaster. I am not going to use chemicals because my daughter is moving things around constantly and loves my trucks. Here is my progress so far. |
09-10-2007, 09:21 AM | #18 |
I ended up using some cheap oven cleaner I found at the dollar store, my daughter is at grandma's house. It seems to be working pretty good. I am on my third overnight application and its coming off very well. Thanks for the help everyone.
10-20-2007, 07:16 AM | #19 |
More progress pics. The oven cleaner worked pretty good but I still had some areas that would not strip. I got out the good old sandpaper and went to work. More pics when I do more body work. I am going to fill the holes in the hood and make some wheel wells. |
