01-04-2009, 08:40 PM | #21 |
Newbie Join Date: Mar 2008 Location: temple
01-04-2009, 11:09 PM | #22 |
Quarry Creeper Join Date: Jul 2006 Location: In a tree top with my chainsaw!!
waiting paitently till someone starts making them. Don't think anyone does yet.:-(
01-14-2009, 07:19 PM | #23 |
Newbie Join Date: Sep 2008 Location: PUERTORICO
| Need support |
01-15-2009, 06:57 AM | #24 |
Rock Stacker Join Date: Nov 2008 Location: Santee
I just recieved the one I bought on e-bay. I will probably install it next week. I will let you know how it goes.
01-16-2009, 10:38 AM | #25 |
Pebble Pounder Join Date: Apr 2007 Location: Everett, WA
I too just ordered the HPI reduction unit for my PTI Goliath. Hope it works, without too much modification needed.
01-20-2009, 06:51 AM | #26 |
| Got gear reduction??
I installed the HPI gru last night. It fits great!! I did have to clearance the front pad that holds my esc and the body pins. I still need to clean up my wiring and take it for a test run..... |
01-20-2009, 08:42 AM | #27 |
Newbie Join Date: Feb 2008 Location: Tacoma
One word of advice; brace up the motor. The PTI motor bracket will flex under load and cause the gear alignment to change. If you do it too much you will strip gears. You can come up with fancy brackets, or just a ziptie under the motor. I don't have a picture, so I'll try my best to explain my setup. Take the gear reduction/motor out. Take two zip ties and make a very loose circle around the chassis rails. So that it looks like this when viewed from the end: --------------- (...[] ...........[]...) --------------- (sorry for the poor ascii art) Now place the gear reduction/motor onto the zip tie sling. There will be two zip ties under the motor. After you get the gears aligned again tighten up the zip ties. Last edited by estill; 01-20-2009 at 08:43 AM. Reason: forum software doesn't ike ascii art |
01-20-2009, 09:26 PM | #28 |
I dont think it will be a problem with the way I installed it. with the 12t pinion, the body of the gru is on the frame. also the back of the motor is on the platform for the esc. It doesnt move at all.
01-21-2009, 08:44 AM | #29 |
You'll be fine then. I'm using the GD600 with a brushless motor from Holmes Hobbies, and I was amazed how much mine flexed.
01-22-2009, 04:51 PM | #30 |
| esc Novak came out with an1/18 esc motor brushless system my question could it be possible to use it on the Golliat actually i'm usinf rooster crawler 55t, what are the advantages if any of this brushless system; thanks:-P
01-23-2009, 08:36 AM | #31 |
Not sure if the 1/18 sized motor will bolt up to the motor plate???
01-26-2009, 02:51 PM | #32 |
Holmes Hobbies sells an adapter. To be fair my Goliath is not a dedicated rock crawler. It is the MMT variety, and I geared it as a rock crawler so I could hand the controls over to my now 4 year old son. The sensorless brushless motor is fun, but I can see where it is not the best suited for rock crawling. |
02-04-2009, 07:08 AM | #33 |
Newbie Join Date: Feb 2009 Location: australia
just wondering if anyone can tell me who has the hpi reduction if the unit comes with the motor to gru pinion. as in the add it didnt say weather they do or not. just ordered 1 from the states so i have at least a nice three week wait till it gets here |
02-04-2009, 02:37 PM | #34 |
| It does...come with a 15t pinion.
02-05-2009, 03:26 AM | #35 |
thanks mate i take it they are 48 pitch?
02-06-2009, 11:43 PM | #36 |
Newbie Join Date: Jan 2009 Location: australia
Dont know what pitch they are but i have a mate with one , so i'll go and check for you( have to wait small as he is a bit obese and has trouble getting up to answer the door)
02-07-2009, 08:02 AM | #37 |
| no.....................you rock! i picked this smiley coz it looks like a cyclops with a vag in the middle. |
02-07-2009, 10:36 PM | #38 |
| need some help
Add the GRU hpi and sudenly start stripping gear any sugestion on what to do; the improve was great with that exception help is welcome and apreciated |
03-08-2009, 06:28 AM | #39 |
same deal! gear reduction while being the best gearing finally, is an instant drive shaft snapper. anyone got any info on upgraded centre drive shafts. i saw somewhere to convert to t-maxx shafts but i could not find what to do to connect it to the centre trans?? any info would be great cheers |
03-08-2009, 12:39 PM | #40 | |
Newbie Join Date: Jan 2009 Location: Bloomingdale
Here you go buddy: Putting sliders on your GRC Im looking to do this myself. Once my stocks break it will be project B. | |
