| | #1 |
| Rock Stacker Join Date: Sep 2008 Location: ontario, canada
| hi i am in the middle of getting ready to start building my custom berg based crawler and was going to use a set of berg axles but after seeing the bully axles i am wondering if these would be better. they look like there are built better and i like how the front stearing goes with the xvd instead of dog bones. any thoughs about using these? also if some one can tell me what the width of the berg axles based on the messerments on the site its the third picture down http://rc4wdstore.com/product_info.p...roducts_id=846 thanks Last edited by rc-guy; 12-21-2008 at 06:44 PM. |
| Sponsored Links | |
| | #2 |
| Rock Crawler Join Date: May 2007 Location: Franklin ME
| Berg axles with appropriate wheels will have a better scrub radius. |
| | #3 |
| Fuzzy Nudger ![]() Join Date: Mar 2008 Location: N. Ridgeville , Ohio
| Berg axles are wheely king width and Bully axles are Axial width .If that puts it in any better perspective sorry about the no measurements , my Berg axles with wk offset wheels are 10" outside of rim to outside of rim. |
| | #4 |
| RCC Addict Join Date: Jul 2008 Location: Sin City
| Bully Comps are 7.6 inches. Almost identical to axial ax10 axles. I have a set now in testing and they seem to be doing well so far. |
| | #5 | |
| RCC Addict ![]() Join Date: Dec 2007 Location: Ward, SC
A few things that come to mind for me would be durability, parts avalibility, greater wheel variations, good customer service etc. | |
| | #6 |
| I wanna be Dave ![]() Join Date: Jan 2004 Location: Detroit
| Bully's built better than Bergs? How can you state that without any testing being done on the Bully's. They've just been released and do not have the hours of hard testing on them. It's too early to think the Bullys are either built better or have some advantage yet. |
| | #7 |
| Quarry Creeper Join Date: Jun 2008 Location: phx
| I'm new to the berg scene and I'm still going through the beginning stages of getting all the performance I can out of them. This involves clocking the axle, modifying the steering to get more out of it, custom wheels to account for the width, loctite all the screws, etc. If the Bully's are as durable as the bergs then I'd go w/ the Bully's. The Bully's seem to have all the initial modificaitons accounted for. And if it uses standard vs. metric gears then I may just get a set myself and sell the bergs. |
| | #8 | ||
| RCC Addict ![]() Join Date: Sep 2007 Location: Westland, MI
| | #9 |
| Right now its proven the Berg's are the better, they've won comps and their problems are known and out there (use axial Stub axles and use loc-tite before running). Bully's are unknowns. Even stating their XVD is better is a joke, take a peak as previous XVD's RC4WD has released...any of them fixed yet? RC4WD is RC4WD they haven't changed. I hope to be proven wrong, but history teahces us many things. Last edited by binaryterror; 12-22-2008 at 10:52 AM. |
| | #10 |
| Quarry Creeper Join Date: Sep 2008 Location: sterling VA
| the BERG is the shizznitz! lol , just kidding, only time will tell at this point, although not alot of people are using the bullys, as more people use them, people will figure out the weak point and think of a solution to fox it. It is much like when the berg was first released. It is just now that people are using it to the fullest. |
| | #11 | |
Its ok man. I don't know what your beef is with RC4WD yet I do know this is a non-biased opinionated thread. | |
| | #12 | |
| | #13 |
| mm both side are = with there points ...lol making this harder to pick. i do like the berg axles and the fact parts are easy to get and that the axial parts are shared but like the way the bullies look and the way they are made. to add the only reason im even looking at the bullies is because i dont like being like every one else out there, copy cat, but if it's not broke don't fix it. i like to makeing things myself i am making a tube chassis for what ever 2.2 twin motor i build and will be running panther tires on it still desiding on motors. 50 rear 45 front or lower. as fare as links go will be making them to using stock ones as templates. wheels will be DH ProComp and will use a tekin speed controler thanks for the replys guy and helping make this harder to deside but i think maybe i will stick with the bergs for know .. i just think the bullys in time will be beter suited |
| | #14 |
| Just remember with the bergs you can only run one offset on your wheels to keep your track under 10 inches. If you dont mind that then it doesnt really matter which one you run. I prefer running wider in the front and narrower in the back for angling out of gates. But its all in preference. I like the Hot Racing axles and the Bully's. But i wouldnt throw a set of bergs away either, its all in the prefrence. |
| | #15 |
| ... Join Date: Sep 2005 Location: USA
| With all the different offset beadlocks you can get now. You can't really say which is better. The Bully's out weight the Bergs. So if you like the idea of heavier axles. The Bullys fit that. If you already have some beadlocks from an old Ax-10 build. Then your good to choose the Bullys. But if your starting from nothing. Either way is a good choice. Both axles are nice. The Bullys will hold there own and see many Wins in 2009. It all depends on the set up and driver. I plan on building both and keeping both. I may sell one off later down the road. Just buy looking and tearing into both axles. The Bullys Win. The machining and finish is top notch and above the Bergs. The Bullys make the Bergs look like a step above Wal-Mart Grade. The Bullys had alot of input from some of the Top members here on RCC. They just didn't get lucky on the design like OCM/Enroute did. Like I said you can't go wronf with either on. |
| | #16 |
| | #17 |
| RC-Guy: My buddy XJ Farmer has those. With even the narrowest offset allowed on a Berg they are still wide. His with the same foams/tires (Panthers) he comes in at 10.5" while mine with the DNA Sniper Berg Offsets I'm at 10.125". Not a huge difference of course, but it does matter to some. |
| | #18 | |
I'm not bashing Burg axles it's just that you need to cut and chop them right out of the box. And they are too wide. RC4WD is trying to fix that and give you an axle that you can just bolt up and go. Last edited by hitman46mod; 12-22-2008 at 03:05 PM. | |
| | #19 | |
RC4WD's Bully's might be great, but lets see someone test them and win with them at a Comp...there are some coming up like Motorama. Shouldn't this be in the Bully/RC4WD forum? | |
| | #20 |
| i thinks that my question was fine to post in this forum i received the answers i was looking for guess i shouldn't post any more on here :-( |
| Thread Tools | |
| Display Modes | |
