Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > RC4wd Bully
Thread: My Bully Build 4th 2009 Comp Rig
Old 01-08-2009, 02:28 AM   #1
Default My Bully Build 4th 2009 Comp Rig
Well I finally got this thing a roller that I'm happy with.
Spec's
Axles: Rc4wd Bully's
Wheels: Bergs soon to be Mayhems
Tires: Panthers
Chassis: Custom
ESC: CC SW
Servo: MG946R
Radio gear: DX3R
Battery: Small 3 cell Lipo
Front and Rear Digs
Body: Jp newest Comp body (not out yet)
Motors: Venom 50T handwounds
The chassis uses 60mm Shocks in the rear and Torsion in the front like KK's design, but I was able to get pretty close to the same Link Geometry has the DoubleD had. The chassis is under 10in long and 2.5in tall. Each side plate weighed .7oz... I went with the KK lower links. I've been wanting to use these links for some time. but they just wouldn't fit my other rigs well. This chassis worked out great with the Bullys huge gear housing on the front. The rear I had to flip the axle. The housing was hitting the chassis. With all the different mounting point for the upper links. I was able to use Revo pushrods from the front and rear upper links. I'm pretty stoked to get this running. It just has a mean look to it. I just hope these Bullies can prove themselves for the 2009 Comp season.
On to a few Pic's.
The way it sits right now. It has a 12-3/8in Wheelbase and 3-1/2in Center clearance. Might lower it down to 3-1/8in, but I'm going to run it like this for a while.
run2jeepn is online now   Reply With Quote
Old 01-08-2009, 04:14 AM   #2
Looks really good, is there a reason why everybody running those lower links run them with the recess facing out?
rckcrawler is offline   Reply With Quote
Old 01-08-2009, 05:47 AM   #3
Thanks.. On the links I can't answer that. I do plan on taking them back off and sanding all the edges down to give them a rounder shape.
Old 01-08-2009, 07:05 AM   #4
If you take the edges off the corners they become noodles.....way too flexible. Maybe ask Jeff, but I believe that taking off the corners takes away the strength of them.
wrightcs77 is offline   Reply With Quote
Old 01-08-2009, 07:26 AM   #5
hitman46mod's Avatar
Nice, job looks like alot of people are trying torsion or semi torsion rigs this year.
hitman46mod is offline   Reply With Quote
Old 01-08-2009, 08:05 AM   #6
binaryterror's Avatar
Will you be bracing the chassis? As in by the shocks?
Looks good...I have never tried torsional.
binaryterror is offline   Reply With Quote
Old 01-08-2009, 08:05 AM   #7
I've been running Torsions for years. This is the first year I've ran Shocks.. Figured I'd slowly ease my way into using Shocks.
Old 01-08-2009, 11:41 AM   #8
Neat idea, I will be very interested to see how this rig turns out.
carbonuts is offline   Reply With Quote
Old 01-08-2009, 11:46 AM   #9
looks good
heminutt is offline   Reply With Quote
Old 01-08-2009, 12:26 PM   #10
Very neat! Looks like a great platform to start with! Keep up the good work!
matts88yj is offline   Reply With Quote
Old 01-08-2009, 02:49 PM   #11
I like it. The bullys are a tight fit with shocks in most any configuration because the huge gears and pre clocked make for a gearbox in the way. Looks like you found a way around that!
Culetto is offline   Reply With Quote
Old 01-08-2009, 03:41 PM   #12
Looking for scale goodies
Racer4Life's Avatar
Different!! I like it.
I too am interested to see how this does.
Racer4Life is offline   Reply With Quote
Old 01-08-2009, 09:30 PM   #13
I hoping these chassis works out. I've been waiting on it for a couple of Months now.
So am I.... It's just a little be different then everything else out right now.
So far everything has bolted up easy. Besides the Rear axle clearance.
Old 01-08-2009, 09:42 PM   #14
looks great maybe once you get i running you can get some video of it up. how bout some flex pics. i'm gonna be running the kk zero t chassis on my bully's. the bully's are nce and. the fit and finish on these are really nice.
keala is offline   Reply With Quote
Old 01-09-2009, 01:47 AM   #15
More Pic's.. I should have my new motors in anyday now. I might just throw a Cheap ESC in it and get it running faster.
Old 01-09-2009, 08:43 AM   #16
Scattman's Avatar
I smoothed the corners on mine with absolutely no issues whatsoever.
Worked well for me. I smoothed the ends of the links down to the same size as the revo ends.
Smooth as buttah.
Scattman is offline   Reply With Quote
Old 01-09-2009, 09:23 AM   #17
Team Hardkor Crawlers
kasper's Avatar
WOW that looks nice i like the lower link set up very nice
kasper is offline   Reply With Quote
Old 01-09-2009, 02:24 PM   #18
Did you balance the axles before swapping the rear around? I would think it would make one side heavier with both motors facing the same way instead of just unbolting the tubes and clocking them all the way over.
Old 01-09-2009, 04:14 PM   #19
Thanks those are KK Links. He has a new design coming out to I believe.
I don't think it's going to make that much difference if any at all. I've been running my 2.2 Clod the same way for years. I've never noticed any issues with it being flipped.
Old 01-09-2009, 06:02 PM   #20
Nice setup, hope to see some video of it
HITMAN is offline   Reply With Quote
