Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > RC4wd Bully
Thread: Roborg's (Cast) Bully Build
Old 05-21-2009, 11:28 AM   #1
support@rc4wd.com
roborg5000's Avatar
Default Roborg's (Cast) Bully Build
Ive had Jarod's HaVoc chassis sitting here for awhile now and just got these cast Bully's to test so figured now was a good time to try it out. at the same time I got a couple electronics upgrades as well (Futaba Steer servo, PunkRCDig. 2 great additions!
More pictures soon!
Video uploading now.
HAHA! Just noticed where I lost my body clip
JP Custom's HaVoc Chassis
RC4WD X-Locks tires
RC4WD BL01N Rims
110mm RC4WD Sparks Shocks
CC MambaMax
2x Kawada 50T Brushed Motors
CCBEC
Spektrum DX3R
Futaba 94780 Steer Servo (Present day)
Punk R/C DIG (in 3 days)
3cell 1300mah 25c Lipo
Lower links- Traxxas5319
60mm front torsion links
roborg5000 is offline   Reply With Quote
Old 05-21-2009, 05:32 PM   #2
support@rc4wd.com
roborg5000's Avatar
Originally Posted by Jeepial View Post
Sweet.Awesome build!!.I can't wait till you get his one done and get bashing on it..Curious to how those cast Bully's play out..But what are your first impressions on them and are you cutting down on wheels weights due to the weight of the axles?
I wasnt to hip to the use of the cast material but, we will see how it plays out.
V4 axles had no breaks or bends.
I took some pretty good hits Tuesday night without issues.
http://www.youtube.com/watch?v=Bmf0SoFeCvY
My only complaint to this day is the loss of screws from the knuckles but, I had that problem with the originals as well.
Just keep adding the threadlock and eventually they will stay.
I did keep all my wheel weights in order to put the axles to the test.
I should have mentioned I only used 2 cross braces in the rear of the chassis by my 2nd run to gain more flex up front.
I also needed to space my torsion links out on the axle towards the rim more to clear the servo and gain more flex.
Old 05-21-2009, 10:24 PM   #3
TEAM MODERATOR
EeePee's Avatar
Looks like you got that Havoc dialed in pretty damn good already!!
Not really. It worked okay, but it can be better. He needs to tweak that thing.
EeePee is online now   Reply With Quote
Old 05-21-2009, 10:29 PM   #4
support@rc4wd.com
roborg5000's Avatar
I was tweaking there with a few suggestions . Remember ?
I need to order that set of shorter shocks this week and go from there.
Old 05-21-2009, 10:30 PM   #5
TEAM MODERATOR
EeePee's Avatar
I know.
Old 05-21-2009, 10:43 PM   #6
Nice move at 4:45
Nice start...If you need any tips on the HaVoc just shoot me a PM..
Old 05-21-2009, 11:16 PM   #7
I have been using "shake proof" washers on one side of my knuckle bolts....and on the other I am running cap head bolts and aircraft safety wire....both seem to work well...I was gonna try permanent loc-tight..but now that i have the shake proof washers I think I'm good...
Looking good Rob!!! Nice vid too!
I'm dying to get my cast axles now!!! I got a new top secret chassis I'm gonna throw them under!!
keep up the great work.
53 willys is online now   Reply With Quote
Old 05-21-2009, 11:21 PM   #8
support@rc4wd.com
roborg5000's Avatar
Originally Posted by run2jeepn View Post
Nice move at 4:45
Thanks Jarod.
I would say I just need some 80mm shocks and I will be good to go .
You got any ideas on why the knuckle screws keep coming out?I have heard abnout this issue a lot,just curious about thoughts on it.
There is minimal threads in the axle for the knuckle to mount so the screw tends to creep out over time but, not all the time .
Invest in some M3 x 7mm button cap screws.
Old 05-21-2009, 11:29 PM   #9
so Rob how do you like that new dig unit???
Old 05-21-2009, 11:36 PM   #10
support@rc4wd.com
roborg5000's Avatar
I need to check on these "shake proof" washers
Looking forward to the TSC too
I uh, Dig it .
Works wonders man.
To lose one mechanical switch is a great thing. Especially when ive had nothing but problems with all mini servos ive used for DIG!!!
Flawless operation. Switches never got hot either .
Indicator lights are cool when its 1am and you forget which direction front and rear dig is on your radio
Id suggest it . Best $50 I've spent in awhile !
Old 05-21-2009, 11:38 PM   #11
support@rc4wd.com
roborg5000's Avatar
Cool,thanks man..I'm headin to Fastenal tomorrow to pick up an order on some other M3 fastners and set screws anyways!..I love that place..20 bucks get you enough fastners to last a very long time..
Thanks for the reminder i need to take a trip there as well tomorrow !!!
I actually did forget until you said Fastenal
Old 05-22-2009, 10:41 AM   #12
Red loctite seems to cure the loosening screws pretty well. I was having them come loose pretty much every run, then some red loctite seemed to fix the problem. They are tight, but not so tight that you can't get them back out. Just my .02.
davec is offline   Reply With Quote
Old 05-22-2009, 06:44 PM   #13
Gold Star Baby!
Colby's Avatar
bah bah bah. It not gunna werk becuz yu dnt hav ur pink nutz rooobbb
Colby is offline   Reply With Quote
Old 05-23-2009, 06:08 PM   #14
Cool vid.
That's one aweome rig.
BaddClod is offline   Reply With Quote
Old 05-24-2009, 03:28 AM   #15
Gents,
One thing I have noticed is that no one states having degreased the nuts and bolts before the locktite is applied, in model helicopter circles this is de riguer, I'm not trying to tell granny how to suck eggs but it has not been mentioned as far as I can see. Normally Blue locktite is used because once Red is apllied it sticks like Sh!t to a blanket and the devils own to get apart again. With blade revs up at 3K RPM blue works, this almost sounds like a mechanical tendency to unwind the nuts in which case wire locking may be a good compromise between ''tight nuts'' and put together for ever
regards
kevin.
uktwin is offline   Reply With Quote
Old 05-24-2009, 07:21 AM   #16
support@rc4wd.com
roborg5000's Avatar
Originally Posted by uktwin View Post
Gents,
regards
kevin.
There is no grease on these bolts
Old 05-24-2009, 08:22 AM   #17
I just switched all mine out to cap head with a 3mm head with blue loctyte and keep one in my pocket. I started checking for loose screws between each course after losing a weight out of my vanquish wheels so its habit.
Culetto is offline   Reply With Quote
Old 05-24-2009, 01:06 PM   #18
I'm not suggesting there is but lubricant from the manufactuing process can remain in threads, cleaning with alcohol just give the locktite its best chance.
regards
Kevin.
Old 05-24-2009, 01:24 PM   #19
Tight Vid!!!..............
Looks like the different cast bullys are holdn up so far.
clodbuilder99 is offline   Reply With Quote
Old 05-24-2009, 10:24 PM   #20
support@rc4wd.com
roborg5000's Avatar
HAHHA! I know the routine
regards
Kevin.
Understood
So far so good!!
I beat on them a little more at the house this weekend but , no videos from that course because thats just silly
