Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > RC4wd Bully
Thread: ***akrcc deimos bully build***
Old 05-30-2009, 11:38 PM   #1
spittin rocks
crawlski's Avatar
Default ***akrcc deimos bully build***
First of all I would like to thank rocky and everyone involved in designing and engineering the entire line of AKRCC chassis, from mini all the way to super. I have been runnin the 2.2 ARES with much success. I have been wanting to do a BULLY 2.2 build so what better way to do this than to do it with the 2.2 DEIMOS. This chassis was designed with the bergs in mind but I was'nt going to let that stop me, so here goes!
Chassis: AKRCC DEIMOS 2.2
Tires: Hot Bodies Rover (stock foam)
Wheels: Mayhem Engeineering
Wheel Weight: front 12.5 oz./ rear 10.5 oz.
Wheel Wideners: Junfaq 13mm
Track width: 10 3/4"
Shocks: Traxxas Ultra shocks (long)
Shock Length: front- 96.5mm / rear-96.5mm
Shock oil: 70 wt.
Shock Spring: custom cut internals
Shock Limiters: front- none / rear- 5mm
Upper Links: front- 96.5mm / rear 122mm
Lower Links: front- 132mm / rear 136.5mm
Axles: RC4WD BULLYS V.1 with V.2 internals
Motors: Integy 45T
Pinions: stock
Radio: Spectrum DX3R
Receiver Spectrum micro
ESC: Castle Creations Mamba Max
Lipo: Losi 11.1 1350 Mah 20c
BEC: Castle Creations
BEC Voltage: 6v
Steering Servo: Hi-Tech HS7955TG
Total Vehicle Weight: 7 Lbs 1 oz.
Next up is body posts and a new lid.
crawlski is offline   Reply With Quote
Old 06-01-2009, 07:52 PM   #2
Looks good
eron is offline   Reply With Quote
Old 06-03-2009, 01:10 AM   #3
Location: ************************ Why crawl, when you can just jump up there?!
This is one of the BEST DEIMOS set ups Ive ever seen. Those pictures DO NOT do this rig any justice. I love it Matt, great job on it. I like how your pushing those venom links aswell. I like the little mod you did on the skid aswell. ;) This baby looks super planted and its gonna give everyone a run for there money next comp! Keep us updated! Mind sharing your foam set up?
ADDICT is offline   Reply With Quote
Old 06-03-2009, 10:13 AM   #4
Gold Star Baby!
Stormin2u's Avatar
Location: Taylors Falls just hanging with the MNRCRC crew.
She's very pretty crawlski I really like that combination it should be a good preformer.
Stormin2u is offline   Reply With Quote
Old 06-06-2009, 02:48 PM   #5
spittin rocks
crawlski's Avatar
So I have made a few changes on this rig and she seems to be doing great. I raised the belly clearence up to 3 1/4" and got a little more articulation out of her. I will most likely be runnin this rig in our next comp cause it's clearin all obstacles with no problems. Heres a couple of vids.http://s393.photobucket.com/albums/p...8_08090004.flv
http://s393.photobucket.com/albums/p...8_08090006.flv
http://s393.photobucket.com/albums/p...8_08090008.flv
Old 06-06-2009, 09:17 PM   #6
this is a great looking build!!
how are those front lower links working for you? so they are a stock Venom link??
thanks
53 willys is online now   Reply With Quote
Old 06-06-2009, 10:59 PM   #7
spittin rocks
crawlski's Avatar
Yes those are stock venom links. They clear the case by about a 32nd of an inch and are holding up nicely. Thank you for the feedback.
Old 06-13-2009, 10:41 PM   #8
Black Label Crawlers
Jeepial's Avatar
Awesome build you got there!! Love all the red and the use of a AKRCC chassis..Looks like it works very well judging by the videos..Keep up the good work!!
Jeepial is online now   Reply With Quote
Old 06-14-2009, 02:01 AM   #9
I agree with everyone else, looks like a great and capable rig. The truck is very quiet running. Its like its set on whisper mode. No high pitch ESC or servos, and you can barely hear the gears, just a slight brrrrr from the motors. I dont know why, but I like that.
Ripperfi is offline   Reply With Quote
Old 06-14-2009, 02:06 AM   #10
Nice Build.
Nice Vids to.
Xtant3150c is offline   Reply With Quote
Old 06-16-2009, 01:15 PM   #11
K_B
This thing took 1st place at our comp this last weekend. Beat out a new Losi and a Berg, in that order. Good job, Matt!
K_B is online now   Reply With Quote
