| | #1 |
| Pebble Pounder Join Date: Jun 2009 Location: totowa
| Well as the title states which shock stand offs for the losi shocks. |
| Sponsored Links | |
| | #2 |
| I'm Dracula, Bitch. ![]() Join Date: Sep 2005 Location: Houston, TX
| What setup are you asking about? |
| | #3 |
| Scorched Earth MF'r ![]() Join Date: Jun 2008 Location: Central KY
| I'm running a custom chassis made by HomerJ, but I suspect many out there are running a pretty narrow chassis as well. As you can tell from the pic, the top of the shocks are mounted up to a long bolt secured to the chassis with two M3 locknuts that also act as spacers. The bottom of the shocks are secured to the axles with just one spacer, not sure about the size but you can get a general idea from the pic. |
| | #4 |
| Quarry Creeper Join Date: Dec 2008 Location: Aurora Colorado
| I am running: Front Bottom none Front Top revo swivel and 4mm which i believe would total 10mm Rear Bottom 6mm Rear Top Revo swivel and 6mm which should be 12 mm |
| | #5 |
| RCC Addict Join Date: Jul 2008 Location: Sin City
| If you are talking about the upper mount then slide a piece of fuel tubing over an m3 screw and use that for the upper mount. The stock losi ones dont allow much side to side movement. |
| | #6 | |
Mine runs great with the Losi ones and is capable of some very nice lines, but heck I will try anything if it gives me an advantage. | |
| | #7 |
| Now new and improved ![]() Join Date: Apr 2009 Location: hell
| | #8 | |
| | #9 | |
Trucknuts, that is pretty cool, looks like it works well too. | |
| Thread Tools | |
| Display Modes | |
