09-05-2009, 04:47 PM | #1 |
Quarry Creeper Join Date: Nov 2008 Location: UK
| Slingshot links/shocks
Just started my slingshot with new bully axles build Struggling to get my head round the best way/good way to sort out the links Do I use the slingshot links or would I be better off making some? (straight or bent?) Seem to be having an issue with the underside of the vertical plate catching the gearbox Also would I be better running some sorter shocks than the Losi 4'' I was planning use? Or should I limit them? Any sugestions or pictures of setup would be appreciated Ive thrown the towel in for now! Cheers |
09-05-2009, 04:56 PM | #2 |
Rock Crawler Join Date: Jul 2005 Location: MD
I went htrough the same issue, only way I could get it set up was with 60/40. Used slingshot lowers on front uper and lower and uppers on rear uper and lowers. Losi shocks are a bit long, you will have to limit them to 3.5". I will be competing with my setup tomorrow and let you know how worthy it is. Belly height has me concerned at 3 1/4". I am only using this chassis until my kk ST and links show up. I also had to cut off about 1/4" off the rear vertical plate to stop contact with the gearbox. Last edited by jrkilburn; 09-05-2009 at 04:59 PM. Reason: additional info |
09-05-2009, 05:02 PM | #3 |
3 1/4 does sound a bit high what rod ends do you use? I just picked up this chassis this week, maybe wrong choice? I have a Vanquish Incision moa on order, see how that is when it turns up |
09-05-2009, 09:39 PM | #4 |
Newbie Join Date: Dec 2007 Location: Ontario
I set my slingshot up using the lower links on the top and had to make new lower links on the bottom. Shocks, I used T maxx in droop. it worked ok, but I ditched it after the first comp I ran with it. (Droop sucks on MOA)
09-06-2009, 01:33 AM | #5 |
Any chance of some photos?
09-07-2009, 05:13 AM | #6 |
I use revo ends. I wasn't real happy after the first comp with that chassis setup. I am going to wait until the KK chassis shows up to continue with it. I just feel like I am driving myself crazy for nothing. One thing I do like is the 60/40 set-up. Breakovers were buttery smooth but could not adjust rear for climbs. Just my 2 cents |
09-07-2009, 10:22 AM | #7 |
stupid question but what do you mean by 60/40? any chance of a few pics buddy? |
09-07-2009, 11:29 AM | #8 |
RCC Addict Join Date: Jun 2008 Location: Fresno
60/40 is basically a ratio between the rear and the front links. 60/40 is more of a geteral term and doesnt always pertain to actual percentages. ex. the mantis chassis can be refered to as a "60/40" but is actually more like 75/25 the term can also be used in semi droop suspension setups |
