10-11-2009, 07:40 PM | #1 |
I wanna be Dave Join Date: Dec 2005 Location: Gold Bar
| Guys running VP SLW's
So I have been looking at a new set of wheels and fell in love with VP's SLW wheels but I am having a hard time figuring out what hub width to run. So I am hoping for some help from the bully family So I know I want to run the 1" wide wheel. I am currently at 9 3/4" ring to ring width on my bully and I would love to be 1/4 wider in the front from that with the new wheels. So can somebody help me figure out what dang hubs I need to order(I wish they would update there site with bully width info). spanks |
10-11-2009, 07:53 PM | #2 |
I wanna be Dave Join Date: Oct 2005 Location: EvilCrawlerDesigns@comcast.net
The Bully axles are the same width as the Axial.
10-11-2009, 08:18 PM | #3 |
So if I am getting this right. The site shows with axial that the widest you can get with the 725 hubs is 9.17
10-11-2009, 08:59 PM | #4 |
Rock Crawler Join Date: Dec 2007 Location: Ventura, Ca
I ordered the 475 600 and the 725's when I got my SLW's The 475 on back put me right at 10" on the bullies I cant go any narrower though due to battery being on the rear axle Will put the 600's in front and will be just perfect. |
10-11-2009, 09:02 PM | #5 |
no talent hack Join Date: Feb 2007 Location: Redwood City
that measurement should be ring to ring not outside of tire. i think you should be close to 10 inches if not wider with those. i know on a one inch wheel the hex is flush with the inside lip of the wheel
10-11-2009, 09:22 PM | #6 | |
With rubber to rubber I am 10 3/8" and ring to ring I am 9 3/4" | |
10-11-2009, 09:22 PM | #7 | |
Outside of tire to outside of tire with rovers, wider with leopards, yes And yes I have the 1" wheels as well | |
10-11-2009, 09:26 PM | #8 |
10-11-2009, 09:44 PM | #9 |
10-11-2009, 10:19 PM | #10 |
So it looks like my only option is 600 rear and 725 for the front.
10-14-2009, 09:54 AM | #11 |
Rock Crawler Join Date: Mar 2008 Location: lodi
im running a berg offset in the rear. puts me at 9.75 and i still able to put my lipo out back so i have the stock axial vanquish dh's and slws out back with berg offset takes a bit of getting used to but really helps in tight courses alot easier to get a skinnier rear end though the gates then a fat one when you have to take a turn right at the gate to get lined up for the next one. saved me a few points at my last comp
10-14-2009, 11:25 AM | #12 |
Mine will be here tommorow |
10-14-2009, 01:56 PM | #13 |
I joined the Band! Join Date: Jun 2008 Location: Sacramento
we do have this, this should help you figure out where you want to be. http://site.vanquishproducts.com/vp-...dimensions.pdf |
10-15-2009, 03:43 AM | #14 |
Rock Crawler Join Date: Aug 2008 Location: Tucson
Wow thats confusing.
