02-13-2010, 11:16 AM | #1 |
I wanna be Dave Join Date: Nov 2008 Location: Where freedom is earned.
| Bit of info on the top screw holes you should know
After doing my axle shave (again and even closer) I planned to fill the open un-used screw holes with JB weld. The holes filled in nice and the tubes looked uber smooth after filing and painting them. However, When I tried to slide the tube back over the shaft I encountered a "block" inside the tube. Looking through it, I could see a blob of the JB weld on the inside of the tube. It was an easy fix, to just run a flat blade screw driver to it and giv it a tap to break it off, BUT STILL.:? Each axle had one spot like this so I'm thinking of using some set screws or any of the un-used holes up front and dremeling off the excess. I don't want contaminants getting into the housings. Next axle shave, I'll probably use set screws in the holes and dremel them first before I turn'm down. |
02-13-2010, 12:52 PM | #2 |
Old guy Join Date: Jan 2007 Location: Northwest Arkie-saw and we got ROCKS!
This is something you should have stuck in your sticky instead of starting a thread.:?
02-13-2010, 03:57 PM | #3 |
Not everone reads them, I planned on adding the info to my axle shave info but who would know about it unless they were searching through? I thought it would be good info to post for everyone running them standard out of the box.
02-13-2010, 05:02 PM | #4 |
Why didn't you put this in your build thread. instead of a new thread.
02-13-2010, 06:59 PM | #5 | |
Not everyone reads every build. This is info that I felt was worth letting every reader know. How many of us read every build when new info is added? | |
02-14-2010, 04:57 AM | #6 |
I not trying to be a dick or anything, but everytime your thread pops back to the top of the page ,I look to see what you have done. |
02-14-2010, 05:05 AM | #7 |
Rock Crawler Join Date: Sep 2008 Location: Salem,Oregon
ya thats you but not all
02-14-2010, 05:28 AM | #8 |
02-14-2010, 07:28 AM | #9 |
Rock Crawler Join Date: Aug 2009 Location: San Antonio
I think we need some warm weather so we can crawl more and be on this forum less. |
02-14-2010, 01:01 PM | #10 | |
And yes, we some nice weather so we can get back out and crawl! I'm tired of being stuck inside with nothing to do but tinker and not test. I keep debating on weather or not to mod the front axle for the 86Jeep steering mod. I was able to lower the servo down since I milled the top of the axle but I'm stuck on having it exposed like it is now, or having it sandwiched between the axle and the motor.:? | |
