02-16-2010, 10:29 PM | #1 |
Rock Crawler Join Date: Aug 2008 Location: maple ridge
| 4th and G's "Pinch Yo Sack Pimp" Bully Build
Aight so i've been collecting parts for this for quite some time. i'm waiting in some Steering components from some of the stellar RCC Vendors: -East End Machine (Steering Servo Mount) -RC4WD (Machined Rear Housing and Tubes) -Black Label Crawlers Carbon Fiber Upper Links (I'm stoked for these, shoudl look wicked with everything blacked out) -Losi Gold Springs Spec's on the rig: -Bully Axles V2 (Cast front, Machined Rear) Modified for 50 degree steering. -Vanquish SLW 0.7" Rims (725 front hubs, 600 rear hubs -Rover Whites (just like all the cool kids were running before the Sedonas) -Modified Black Label Crawlers Special K Chassis (Full Delrin Version) -Punk RC Dig Switch -Tekin FX-R -JR9001 Ground Servo -Losi Shocks (Soon to be Axial Comp Shocks) -Gold Losi Spring -Turnegy 1350 MAh 3S (mounted on the back axle -35 Turn motors soon to be swapped out for some Holmes Handwounds. Belly Clearance is 3.25" Chassis side plates are 1.75" wide Skid plate is 2" wide. Chassis is 3" tall The links still need to be sanded smooth at the rod ends. The battery mount needs to be made and sent to the powder coater. and the shock mounts are temporary. Once the rig is build it will be taken apart for final fit and finish before wiring. All wiring will be wrapped in black netting to hide the colours. Here are the spy pics (The body is temporary, borrowed from my shafty) Last edited by Kraqa; 02-16-2010 at 11:24 PM. |
02-16-2010, 10:32 PM | #2 |
the electronics will be mounted under the upper arms in the front. hopefully the chassis will only contain the receiver. |
02-16-2010, 11:06 PM | #3 |
Rock Crawler Join Date: Feb 2008 Location: Dortmund, Germany
Hello, looking good so far, very nice link design Punk dig and ESC under the front links should give a tight fit, let us see how it works. Greetings Frank |
02-16-2010, 11:13 PM | #4 |
i've done a dry fit and it looks like it will work. but i need to pick up some solder tomorrow to wire this up. and i'm hoping to have the steering from EEM by friday. |
02-17-2010, 12:05 AM | #5 |
Rock Crawler Join Date: Nov 2008 Location: Maple Ridge, BC, CANADA
Looking good Kraqa! Get her done so we can hit the rocks. one question...you said you were "running 35 Turn motors soon to be swapped out for some Holmes Handwounds" swapped out for 35T HH motors or ??? |
02-17-2010, 08:34 AM | #6 |
RCC Addict Join Date: Jun 2008 Location: Nunya Idaho...
Looking good. I like to see that lid, its nice from the every day grappler.
02-17-2010, 10:25 AM | #7 |
02-17-2010, 10:29 AM | #8 |
02-17-2010, 03:02 PM | #9 |
RCC Addict Join Date: Sep 2007 Location: Westland, MI
Awesome job nice clean build, now go fold some clothes. |
02-18-2010, 11:25 AM | #10 |
i got the rear battery tray made. Waiting for one of our TIG welders to be set-up for aluminum so i can tig an end cap on it. i got it wired last night! pics will follow tonight. this is the cleanest wiring job i have ever don on an RC. All wires are wrapped in the chinese finger trap style of black netted wire loom. super clean. i did install the rear motors wires backwars. kinda funny trying to drive the thing. i've never run a sprun rig before. with the amount of grip you get its cool the dig will grab the front and suck the suspension down effectively increasing the wheel base by abotu 1/8" i guess for those climbs every little bit counts. |
02-18-2010, 12:43 PM | #11 | |
I wanna be Dave Join Date: Jan 2009 Location: laying low
lets see some pics of the wire job! | |
02-18-2010, 07:19 PM | #12 |
Wiring and battery tray |
02-18-2010, 07:21 PM | #13 |
clean wiring job bro. looks good, cant wait to see how she preforms tho! |
02-18-2010, 08:38 PM | #14 |
02-18-2010, 08:39 PM | #15 |
Punk DIG is SIIIICK
02-18-2010, 09:45 PM | #16 | |
care to explain why? this is an impossibility unless your lower arms are parralele to the ground whick unless yoru running droop would be a stoopid low skid plate. I just read through the rules and nowhere does it mention this must be the case in the rules. | |
02-19-2010, 09:59 PM | #17 |
yo! you get your servo mount yet?
02-19-2010, 10:42 PM | #18 | ||
the part in the rules where is says 12.5" maximum wheelbase is in the rules and is the part I'm referring too... you even said in your post that your WB grew by 1/8" so you already know that answer Quote:
Cheers... Last edited by 53 willys; 02-19-2010 at 10:54 PM. | ||
02-19-2010, 10:55 PM | #19 |
02-20-2010, 02:21 PM | #20 |
if you read the rules carfully. they state the wheel base is maximum 12.5" measured at ride height on level ground. so technically there is no mention of your wheel base must remain at 12.5" max through your suspension travel. i know its semantics but...... |
