03-09-2010, 08:09 PM | #1 |
RCC Addict Join Date: Sep 2007 Location: Hallsville, Tx
| UPDATED 3/16/10 My Super Bully build.
I finally decided to build a super, I have like 2 sets of bully axles with plenty of spare parts to build the axles. The axles will be a midwidth which will put the track width at 12" and the wheel base will be 16" long. I was going to build a straight axle for the rear with dig but i decided to go with 4 wheel steering with duel esc's so i can control both motors seperatly so it acts like dig. Here is the list of stuff that i am doing to it: Dual Tekin FXR esc 2 HITEC 7955 servos Spektrum DX6I controller 40series beedlocks that will be narrowed Panther Leopards that will be cut and shut with Moab sidewalls that will measure 7" tall and 2" wide. JPCustoms Hellstorm chasis Delrin links with Revo rod ends JPConcept Gate Crusher body Holmes Hobbies Torquemaster motors(tun not decided) CCbec Revo shocks This thing should be sick when i get it done, here are some pics of what i am at now, will keep you guys updated. [IMG] Last edited by jwalker; 03-16-2010 at 07:50 PM. |
03-09-2010, 09:13 PM | #2 |
Quarry Creeper Join Date: Sep 2009 Location: Granite City (Mt. Airy)
Are you using the 2.2 Hellstrom or the Super Hellstrom?
03-09-2010, 09:14 PM | #3 |
the 2.2 hellstorm, i figured i would use it since that is what i have.
03-11-2010, 12:01 AM | #4 |
I wanna be Dave Join Date: Sep 2006 Location: Stuck on a Rig in the middle of nowhere Utah.
Are you planing on doing any steering modification, or leave it alone sense you are using the medium width axles?
03-11-2010, 06:31 AM | #5 |
i may grind a lil to get some more steering.
03-16-2010, 07:36 PM | #6 |
Got some more work done on my axles. I had to take the long tubes for the front and rear and knotch them so they would fit on the case where the short tube is supposed to go. When i assembled the axles the shafts would not fit correctly, they stuck out to far on the side that i added the long tubes. The steering knuckle wouldnt allow the screws to go into the tube and the rear axle shaft was sticking out to far. I had to do some modifications to the shafts. The front was easy, shaved some material off the inner part of the shaft so it would go into the diff further and the the steering knuckle fit perfectly. The rear took a little bit more work, shaved the same amount off the inner part but when i assembled the tube the axle shaft wold slide out cause i lost the spot where the c clip went. I fixed it buy cutting another groove and 1/8" from its original spot to allow the shaft the stay locked in. I am happy with the end result, the axles are 10" wide from tip to tip. It will give me a 12" track width when i install the wheels which is considered as the mid width super axles. Here is the end result. |
03-21-2010, 09:27 AM | #7 |
| Wheels/Tires Got a package from Jesse to work on. Finished narrowing the wheels down to ~1.8" last night. Used 2 part epoxy and the sectioned out wheel for support. Tires are next. Last edited by Szczerba; 03-21-2010 at 09:36 AM. |
03-21-2010, 10:06 AM | #8 |
thanks man, they look great, now hurry up and get the tires done, lol. no hurry man, my supper bully is gonna be bada$$. |
03-25-2010, 07:02 PM | #9 |
| Tires/wheels done
Here ya go. 40 series leopards. ~7 1/4" tall by 2 1/4" wide Now finish this rig up!!!! |
03-25-2010, 07:19 PM | #10 |
well i asked for suoer leopards and well, i got some SUPER leopards. love them man, thanks. |
