03-11-2010, 12:56 AM | #1 |
Newbie Join Date: Mar 2010 Location: sacramento
| the mars rover
so i thought id share my rig with all you and do a build thread hope you guys like it cast bully's bully chassis duel tekin fxr spekturm ar6100e receiver bec set at 8v modded dx5 transmitter custom ota steering hobbico cs170 servo H.B. rovers (blue) |
03-11-2010, 04:49 AM | #2 |
Rock Stacker Join Date: May 2009 Location: St.Charles
that looks really good dude! Happy crawling! |
03-11-2010, 06:25 AM | #3 |
I wanna be Dave Join Date: Jan 2006 Location: ...the burning end of the rope.
Hey Travis,,,,is this the rig you want the Ockham's Razor chassis for? I gotta ask man,,,how flexxy is your ota link? Another thing,,,what did you do to move your upper link mount on the front axle? |
03-11-2010, 09:27 AM | #4 |
it has good flex the only problem i have with it is the lower shock mount gets super tight so i need to move the hole shock forward that's why i wanted the ochham's razor chassis and the upper link mount got moved when i clocked the axle both axles are clocked at around 10*degs (i moved the holes 5mm clockwise) |
03-11-2010, 09:58 AM | #5 | |
in the steering the curved pieces are stainless steel with a locknut at the knuckle. I test my steering buy holding the front wheels and letting the hole chassis swing back and forth it does this even on carpet, that servo is a beast | |
