05-24-2010, 08:53 PM | #1 |
Rock Stacker Join Date: May 2010 Location: grass valley
| help for new bully owner..
i have a new bully and was wondering about axle maintenance... how often should i check the oil and what kind of oil should i use in the axles.. i know this is probably a ?? that has been asked over and over again. but please help anyways.. thanks
05-24-2010, 09:44 PM | #2 |
Rockin' in Reno Join Date: Mar 2010 Location: Reno
| I can't say exactly how often you should grease the axles since I am new to the Bully as well, but I can say that you need to grease them when you first get them because they just have a light oil on them, and you need to put something like Lucas Red N Tacky or something along those lines on them before you run them.
05-25-2010, 09:41 AM | #3 |
I wanna be Dave Join Date: Dec 2008 Location: anderson
lol i dont rec . doing this but mine r a year old an i have never redid them yet lol they have a good name in bully
05-25-2010, 11:33 AM | #4 |
Quarry Creeper Join Date: Apr 2009 Location: Long Beach
i change my gear grease(white lethium) about every 2nd or 3rd comp just to be sere i have no problems....just the way i roll Last edited by samaruki; 05-25-2010 at 11:37 AM. |
05-25-2010, 09:53 PM | #5 |
Quarry Creeper Join Date: Apr 2010 Location: Hells Hole
If in doubt change it out. I have yet to see a schedule like on 1:1 engines , i would say depending on how hard and often you run check it monthly or even more if your driving it daily. It also lets you see what wearing and going to need replacement so you can get the parts ordered for when or if they go out.
05-25-2010, 11:25 PM | #6 |
I ran mine for about 9 months... 10-11 Comps.. Never changed or even cracked the case open. Tore it down for the 2010 season. They were fine.. Clean everything, lubed the bearings and re-greased the gears. If you use Red-n-Tacky don't fill the case up. Just put enough on the gears to run smooth. If you over grease the gears. It puts a load on the motor that you don't need. White Lithium doesn't seem to stay on the gears as well. When it heats up. It spins on the gears. You end up with more grease on the case and not on the gears.
05-26-2010, 08:13 AM | #7 |
Quarry Creeper Join Date: Dec 2009 Location: Tehachapi, Ca
use ther mobil 1 red grease and it works great its only 5 or 6 $ for the tub and it should last for a long time
05-27-2010, 04:29 PM | #8 |
thanks to everyone for the help and advice..
