07-19-2010, 07:51 PM | #1 |
Rock Stacker Join Date: May 2010 Location: N/A
| Lightened gear set
I'm setting up a bully axled rig and I was wondering if any one as drilled holes in the gears like the ckrc droid. Seems like a good idea if a guy had time on his hands. Weight loss up top and less rotational mass. Can it be done? Has it been done? Any ideas would be great.
07-19-2010, 08:37 PM | #2 |
0 0 Join Date: Jul 2006 Location: FT. Thomas
give it a shot. ive thought about it but i really don't feel like tearing mine apart and driving 40miles to my brothers to use his drill press only to mess up my gearset. if you pull it off let me know what drill bits to use |
07-19-2010, 08:51 PM | #3 |
RCC Addict Join Date: Jun 2008 Location: Nunya Idaho...
Im pretty sure I saw someones thread in here that did it do their bully's, cant remember who though. Doesnt seem like you would lose enough to make it worth the trouble, just my opinion though.
07-19-2010, 09:10 PM | #4 |
RCC Addict Join Date: Jul 2009 Location: Reno, Nv
How much does a gears set weigh? You could lose an 1 or 2 oz's per end i bet. I was thinking about looking for a used set to test it out i'm unemployed at the moment. Government work doesn't pay to well so i am going to have to wait.
07-19-2010, 11:22 PM | #5 |
Quarry Creeper Join Date: Sep 2009 Location: Granite City (Mt. Airy)
| Lightened Gear Set
Drilled mine awhile back. Used a 5/16 and 7/32 bit. Before After Almost an ounce. .99oz weight lost. |
07-20-2010, 04:13 AM | #6 |
1oz is alot of rotating mass. could you tell a difference in power at all?
07-20-2010, 06:15 AM | #7 |
Newbie Join Date: Oct 2009 Location: oceanside
I tried drilling out a new set of gears and they appear to be hardened... The gears laughed at the drill press.. |
07-20-2010, 04:29 PM | #8 |
07-20-2010, 05:05 PM | #9 |
I wanna be Dave Join Date: Dec 2005 Location: Gold Bar
Interesting. Not a bad idea really since I can't see taking away from the strength doing that. I might have to try that but I will need to get another set of the 1 piece gears.
07-20-2010, 06:54 PM | #10 |
07-21-2010, 09:20 AM | #11 |
Thanks for the info. I was guessing about 1 to 1.5 oz. total weight reduction, so 2 oz is great. It rotational weight to boot. I will be giving it a try.
07-21-2010, 09:54 AM | #12 |
Quarry Creeper Join Date: Jun 2009 Location: Fredericksburg
Great mod I've been running them like that for months, no problems at all. Mine aren't nearly that well lined up though I thought the drilling would be very hard, but with a sharp bit and a drill press it went easy. |
07-21-2010, 04:05 PM | #13 | |
| Luck Na, I just marked where I wanted the holes and like Rocks R. Good said; A good sharp bit & drill press. Also, I used a laser to get them as even as possible. I'll try to get some pics of that up later. Quote:
Thanks for the compliment. I thought it would hard drilling too. I've had no problems with mine either. Last edited by Gear Jammer; 07-21-2010 at 04:08 PM. | |
08-27-2010, 02:22 PM | #14 |
Lightened the gears in my 65:1 SuperBully cases. Before After Before: 4.039oz. After: 3.175oz. Weight loss: .864oz. This is what I use to get my holes as even as possible. |
08-27-2010, 07:26 PM | #15 |
Rock Crawler Join Date: Nov 2008 Location: Maple Ridge, BC, CANADA
i just drilled my gears two days ago. still have not installed but they are complete. Drill press just takes time. Its hardened steel. i would drill like 4-5 hole then sharpen my bit with a grinding wheel. Easy mod, can't see it not helping......
08-27-2010, 09:08 PM | #16 |
Rock Crawler Join Date: Aug 2008 Location: maple ridge
i cannot see why RCC doesn't offer this as an optional item. i can not see the gears breaking only the teeth chipping so drillign out the gears seem to be a great option. Combine that with grinding the axle tube to get the servo down low and ur set! |
08-27-2010, 11:13 PM | #17 |
| You need better bits. I drilled every hole in four sets (2.2 and Super) of the hardened gears with the same two bits. |
08-28-2010, 12:07 AM | #18 |
