09-06-2010, 09:31 AM | #1 |
Pebble Pounder Join Date: Feb 2009 Location: Highlands Ranch, CO
| Simple Shock Mount
I thought I would post up a simple but (so far) effective way I found to mount shocks that don't come with an upper ball (Duratrax, Losi, Taxxas, etc.). I might not be the first to come up with this but I haven't seen any posts so I thought I would share. Hopefully some will find this helpful. It's very simple. Take a ball end from a Traxxas rod end and remove one side with a dremel cut-off wheel: Mount up with an appropriate sized spacer on the body side and a small washer on the cut-off side. On my fronts I have found it works better with a spacer on each side. And there you go: I have been running this for a couple of months and it is working well. I did have to play with the washers a bit depending on the angle of the shock. Overall, it is a lot smoother than fuel tubing. EXW |
09-06-2010, 12:13 PM | #2 |
RCC Addict Join Date: Jun 2008 Location: Nunya Idaho...
Nice job.
09-06-2010, 01:34 PM | #3 |
I wanna be Dave Join Date: Mar 2009 Location: SW Missouri
I like that; won't squish up and bind like fuel tubing. |
09-06-2010, 03:02 PM | #4 |
Rock Crawler Join Date: Nov 2008 Location: Maple Ridge, BC, CANADA
side note question: what did u use for body panels? |
09-06-2010, 06:37 PM | #5 |
