01-19-2011, 09:12 PM | #1 |
Newbie Join Date: Jun 2010 Location: englewood
| savox servo
i just got my bully axles and am in the process of a new build........just wondering if anyone has any experience with savox servo's......good or bad.....jus wondering.......
01-20-2011, 03:22 AM | #2 |
Pebble Pounder Join Date: Jan 2009 Location: Helsinki, Finland
I've broke one 16kg savöx (Savöx SC-0251MG) and one cheaper 20kg-version copy (brand Power HD or something) with my bully axles. Their gears are not the strongest material, but they'll last longer if you run plastic servo horns. I didn't break my second 16kg version when using plastic arms and it lasted 'bout 4 months. After that I bought a better Airtronics 'pro' servo. Especially the SC-0251mg is a good deal for the price but if you can afford to a bit more expensive Futaba's, Hitec's, Airtronics' or some other good brands servos, buy them instead of Savöx. |
01-20-2011, 06:33 AM | #3 |
I just started using the 1268 (277oz/in @ 6V) in my AX-10 and it works well, as good as any other servo. On the down side it seems that the Savox servos are a little more power hungry but if you're running them off a BEC then it doesn't matter except for run time. I'm using a Hobbico CS-170 in my Bully and that is holding up well considering that it was in my Losi for nearly two seasons. |
01-20-2011, 10:10 AM | #4 |
Quarry Creeper Join Date: Apr 2010 Location: Centurion, GP, RSA
Go for the Savox SC-1256TG.
01-20-2011, 11:18 AM | #5 |
01-22-2011, 12:33 PM | #6 |
thanks for the help guys.............i will have to save some money either way........
