02-23-2011, 05:10 PM | #1 |
Quarry Creeper Join Date: Jun 2010 Location: NIXA
| Fallin Apart 1st HaVoc build now passed onto my Dad
I started with a bully rtr from RC4WD its all stock except tires and wheels and the body mounts, I recently got a JPcustom HaVoc chassis that I got that was used but in good shape. onto the pictures after a few minutes of taking it apart I had the rear off Last edited by fallin apart; 08-02-2011 at 08:13 AM. |
02-23-2011, 08:02 PM | #2 |
got more work done on it took the front off then i had too find some screws to fit the HaVoc chassis for the links kinda of a pain to get the right size screws to fit the lower links with what i had laying around, finally found some in my tool box that were all the same size going to be running the stock shocks for now untill I can find some better one's front axle mounted to the chassis, working on the rear axle now, going to leave the rear shocks on it for now to see how well it does, its not really set up for torsion right now but it flexes pretty well for just putting the links in the hole's |
02-24-2011, 06:21 AM | #3 |
I wanna be Dave Join Date: Mar 2009 Location: SW Missouri
Good start Austin, it looks a little high, though. What is your ground clearance at the skid? You might need to limit the shocks until you get some new ones. Also, you need to run cross braces between or near the upper shock mounts. I eventually ran my HaVoc with shocks on all four corners, but you have to "lock out" the torsion end with the braces so the shocks don't fight the torsion twist or it gets too sloppy. My torsion end was in droop to get the right ride height, left the other end sprung. Let me know if I can help with anything. Last edited by papabash; 02-24-2011 at 06:25 AM. |
02-24-2011, 06:40 PM | #4 |
from the bottom of the skid it sits at 4.5" which I think sits a little high I plan on getting some 90mm yeah racing shock to put all the way around which should lower the truck some.
02-24-2011, 07:43 PM | #5 |
Yeah, that's a little high. The highest point on our slanted skids is about 3 3/4"; on your level skid, you might want around 3 1/2". The 90mm shocks will help a bunch, and the Yeah Racing shocks have worked well for me.
02-24-2011, 08:00 PM | #6 |
Yeah it may sit a little lower once I get the electronics in it but not by much I got a punk dig coming for it that may get here soon and I have to order some ultra high clearence links for it.
02-24-2011, 08:12 PM | #7 |
The Electronic's won't lower it much at all... You just need some Shorter Shocks. 80mms Should work fine.
02-24-2011, 08:29 PM | #8 |
What would be better 80mm or 90mm shocks
02-24-2011, 08:33 PM | #9 |
I would run 80's. Are you going to leav some torsion or brace it up solid?
02-24-2011, 08:58 PM | #10 |
Im going to leave a little torision and see how it works but I dont think im going to do full torsion on the rear.
02-28-2011, 03:48 PM | #11 |
haven't done much on it, went outside to take some flex shots, it has a lot of flex |
02-28-2011, 07:51 PM | #12 |
Quarry Creeper Join Date: Nov 2009 Location: Sunny cali
If you want to save some $$ just limit you front shocks,the shocks are pretty good they are just too long.....and go with the full torsion in rear ...then get some soft Rovers and you are good to go Listen to Run2jeepn!! he knows what he talking about...(been there done that ) |
02-28-2011, 11:11 PM | #13 |
Quarry Creeper Join Date: Jul 2009 Location: St. Charles
grave digger style, so tall lol i'd limit the shocks and try it out, if you don't like it then buy whatever you think. |
03-01-2011, 06:20 AM | #14 |
Wow, that's some serious flex!! Try to get it so that you have enough to put one tire on a soda can, that's about all you want. Much more than that and the rig will fold under itself. You still need to put a brace between the front shocks, that will help take some of the flex and slop out. I know you want to try the torsion/twist together in the back, but I think you'll end up either bracing it and running shocks, or taking the shocks off. But.......... I have been wrong once or twice before. |
03-10-2011, 06:26 AM | #15 |
Any updates Austin? Just 10 days till our first comp! |
03-10-2011, 08:00 PM | #16 |
yeah it would be done by now, but I'm still waiting on my punk dig (20+ days) and the shocks haven't got here yet and have to hopefully go to jarods this weekend and pick up my links what would be a good weight oil to run with the 80mm shock |
03-10-2011, 09:51 PM | #17 |
Rock Stacker Join Date: Jan 2009 Location: halfway
lookin good austin, im definaty gonna have to upgrade to one of jarods chassis' soon. cant wait to see it at the comp on the 20th.
03-11-2011, 04:26 AM | #18 | |
I think I have an old-school dig switch you can borrow till your Punk comes in. Let me know if you want it and I'll dig around and see if I can find it. Last edited by papabash; 03-11-2011 at 04:28 AM. | |
03-11-2011, 10:35 AM | #19 |
yeah I would like to borrow it till mine comes in
03-11-2011, 10:48 AM | #20 |
Found it! I'll PM you about picking it up.
